turbo timers
Old May 10, 2004 | 09:53 AM
johnnysixer's Avatar
turbo timers
alright. So I'm picking up my evo tonight and I'm wondering what turbo timers all you people are using....gotta figure out which one to get.
Old May 10, 2004 | 10:04 AM
IgotaWhiteOne's Avatar
im using the blitz auto timer 3
Old May 10, 2004 | 10:05 AM
midwestmonster's Avatar
HKS Type 0
Old May 10, 2004 | 10:11 AM
hotrod2448's Avatar
I've got the Blitz FATT with Blitz harness.
Old May 10, 2004 | 10:14 AM
1QWKEVO's Avatar
Blitz FATT DC w/ HKS harness
Old May 10, 2004 | 10:29 AM
I'd probably go with something nice and compact....the offerings from blitz sound good. installed yourself or had someone else do it?
Old May 10, 2004 | 11:20 AM
sillypuddy's Avatar
greddy!
-joe
Old May 10, 2004 | 11:45 AM
TYRONEBIGGUM's Avatar
HKS type 1 with HKS harness, has 0-60 60ft RPM and quarter mile
Old May 10, 2004 | 11:58 AM
ImSoEvo's Avatar
the hks type 1 is a good unit.. has lots of extra features if you need or want it
Old May 10, 2004 | 11:59 AM
interesting.....
Old May 10, 2004 | 12:02 PM
it also has a shift light
Old May 10, 2004 | 01:06 PM
1QWKEVO's Avatar
installed myself, i've done many installs but basicly its a 2 minute job...
Gain access to the ignition switch, remove the harness plug the new harness in between the switch and old harness, plug the turbo timer into that and tap the purple wire to the handbrake and thats it.... if you don't care about the auto shutoff when the handbrake is dropped then just ground the purple wire.... Very easy install.
Please don't use the above statement as a guide it was a brief summary only
Old May 10, 2004 | 11:31 PM
bullfrg's Avatar
Apexi, just installed this week and I have no complaints. I used the HKS harness also.
Old May 11, 2004 | 05:50 AM
sillypuddy's Avatar
I have both the blittz fatt and the greddy one, both are in boxes.. which one would you pick?
also did you have to take apart the lower dash to take off the covers for the steering column?
-joe
Old May 11, 2004 | 06:03 AM
UFO's Avatar
UFO
-joe
Yes, I can't get the lower portion of the steering column off without removing the lower dash. It's just 2 screws (or 4 screws if you disconnect the hood release), acouple of clips on the switches, and 1 10mm bolt so it's not too bad.
