Funny Fuel Problem...
Here goes....
Last time I filled up my tank with gas a strange thing happened. I filled up before leaving for a 1-hour trip home. Filled up all the way. BUT, the needle on the fuel gauge only rose to halfway between full and 3/4 full. So I figured the pump prematurely cut off. When I get home I fill it up again to be sure. It was as full as it would get before gas started spilling out. Needle still only rose to halfway between full and 3/4 full. After 2 days of driving, the needle rose to the full line. (It usually rises until it's a little bit above the full line). Over the past week, while driving around, the needle has fluctuated between the full mark and the 3/4 full mark. I'm guessing it's something to do with the sensor in the tank that measures how much fuel is remaining. I'm wondering though, is the sensor on the fuel pump? My fuel system is all stock except for a Walbro pump. Could the pump be the cause? Any input would be greatly appreciated.
whats really funny is I just asked about this like a week ago....
https://www.evolutionm.net/forums/sh...6&goto=newpost
damn, there seems to be a lot of people having this problem, even sti's. Has anybody figured anything out yet. It seems the scubies are resetting the ecu and that worked for a couple people. any word for sure
Originally Posted by SilverEvo8owner
you might have bent the arm of the float in the gas tank that read how much gas is in there
