Car starts and idles, but breaks up BAD!!!
Hey AustinEvo8, you may have very likely checked this already but check ALL of the little vacum lines on the intake manifold, and definitely check your vac lines behind the intake manifold on the driver's side that go to the egr valve, zip tie all of the lines that you can get to, everytime I have this problem it's a new line that I hadn't noticed popped off the intake manifold sometimes. good luck
sorry to hear of your troubles. i had a similar issue, turned out to be i had some crud like road grime on the the mass air sensor, i cleaned lightly with a towel and my problem went away..
No, its directed to AustinEvo8.
The reason I say that is because from my experience just putting the walbro in without any fuel control makes it run extremely rich above 5000 RPM
