No crush washer on drain plug?
Old May 28, 2004 | 03:54 PM
EvilBlueEvo8's Avatar
I changed my oil today on the evo for the first time (first oil change overall) and I don't think there was a crush washer between the pan and the drain plug from the factory. I didn't drop the plug and it wasn't on it, it wasn't stuck on the pan, and it wasn't in the used oil (not that I saw). anyone else have the same thing happen? anyways i put in the copper one supplied by the dealer when i got the the filter on and there is no leaks so hopefully its ok.
Old May 28, 2004 | 04:00 PM
o3evo8's Avatar
Veteran: Air Force
check the drain plug! mine was painted on pretty good the first time i changed my oil.
Old May 28, 2004 | 05:50 PM
gonzo's Avatar
Yeah same here. Mine was painted on and stuck on the plug itself.
Old May 29, 2004 | 05:52 AM
Fourdoor's Avatar
I didn't have this problem myself, but from the responses it looks pretty common. If it isn't leaking don't mess with it until your next change, but at that point I would follow the advice of the other guys and see if it is painted on
Keith
Old May 30, 2004 | 08:27 PM
well i can't do it now since i refilled the motor and i'm not draining it to check. i'll just wait till next time.
Old May 30, 2004 | 08:41 PM
WildRice's Avatar
The filler plug washer part # is MD050317
ak47po
33
Mar 21, 2016 11:31 AM
nrt5pitt
Feb 5, 2011 04:31 PM
jberb55
27
Oct 28, 2008 02:27 PM
ZeroFighter83
Jun 12, 2008 02:17 PM
krafty
14
Mar 5, 2007 11:18 AM
