Removed HKS EVC = Not boosting past 10.5psi
Old Jun 3, 2004 | 06:25 PM
  #31
memo3's Avatar
I had the same problem and put the restrictor pill and the problem fixed....
Old Jun 3, 2004 | 06:26 PM
  #32
Shahul X's Avatar
Im hoping it'll work.... if not maybe its the WG? lets just hope.........
Fimotorsports..... nice turbo kit , thats the one I want.......
-shahul
Old Jun 3, 2004 | 10:19 PM
  #33
LateSleeper's Avatar
Originally Posted by fimotorsports
there is 2 restrictor pills, that's interesting.
Very true... there's a second pill in the short 3" vacuum line from the Tee to the turbo.
Old Jun 4, 2004 | 06:33 AM
  #34
EVOag's Avatar
Registered User
oh my god...i think thats the damn problem...i used a new vacuum tube from wg actuator to boost controller and reused the old wg actuator vaccuum tube to the "T" that connected to turbo.
You guys are saying not to reuse that tube and just use a new one....damn.
wait I just reread what I wrote. Are you guys saying:
1. Use all new lines
or
2. Use the existing lines with restrictors in them.
I like 1 a whole lot better.
Old Jun 4, 2004 | 07:16 AM
  #35
Mui3z's Avatar
shahul, did u fix the problem?
Old Jun 4, 2004 | 07:39 PM
  #36
Shahul X's Avatar
didnt work..... anything else? could it actually be the wastegate????
-shahul
Old Jun 4, 2004 | 08:40 PM
  #37
timzcat's Avatar
Well I have to repeat the restrictor thing. The one up by the the solenoid would not cause your problem but there has to be the one in the short (2 in.) hose that goes to the actuator. If it is missing then the wastegate will open on it's spring rate which is 10.5 or so. The restirctor hold off pressure so the solenoid can modulate it.
Old Jun 4, 2004 | 08:41 PM
  #38
timzcat's Avatar
Shahul X
I have this short hose with the restrictor if you want me to send it to you on Monday. The restirctors are approximately a 5/64 opening.
Old Jun 4, 2004 | 08:56 PM
  #39
Shahul X's Avatar
i think I changed the whole thing.....i ordered them from Mits and comes as a whole package.... it came with 3? lines with the resitrictors.... AMStuning feel free to jump in and see f this is something differant? IM unsure at this point.....
-shahul
Old Jun 4, 2004 | 09:30 PM
  #40
timzcat's Avatar
Yes three lines on a tee. I just looked at my car because the MAF pipe is not on and I was mistaken. The hose with the red on the end goes to the actuator and the short 2 in hose goes to the turbo outlet. Obviously the long hose goes up to the solenoid. Here is the diagram with color markings.
Old Jun 4, 2004 | 09:35 PM
  #41
timzcat's Avatar
A better representation of the hose positioning then above.
Old Jun 4, 2004 | 09:36 PM
  #42
Mui3z's Avatar
hey timzcat, can ya post a pic of your engine bay? i wanna see how all your hoses are connected from the evc
thanks
jeff
Old Jun 4, 2004 | 09:47 PM
  #43
timzcat's Avatar
Sure.
The small hose goes to a vacuum source on the intake manifold and includes a filter (I am using a vacuum distribution block)
The middle hose on the EVC solenoid goes to the turbo compressor housing and includes the filter. Note the moddle port has a built in restrictor which mimmicks stock.
The end large hose goes to the wastegat actuator.
The second pic show the vacuum dist. block up on the firewall.
Old Jun 5, 2004 | 07:12 AM
  #44
AMSTuning.com's Avatar
We tried MachV's test with an open wastegate; drove the car gently and it did NOT overboost. I am starting to think its the wastegate. If the problem was pill or vacuum related it would atleast move around a little bit, the boost is stuck solid at 10-11. Solid.
Old Jun 5, 2004 | 07:17 AM
  #45
Oh, also, I forget if I mentioned. We tested the voltage at the solenoid plug. Its getting constant 14 volts at any point , does not flactuate. Service range in the manual is 4-14 volts, the solenoid also never throws a CEL light.
