HELP!! My EVO wont start!
Hi fellow EVOists
My car went to the body shop to get repaired from a rear end collision and while it was there, something happened and now it wont start. Here are some important details:
1. The car has the AEM EMS, not stock ECU
2. The battery was bad and has been replaced
3. I've checked all the obvious fuses in the fuse box under the hood.
4. The spark plugs are getting spark.
5. There are no obvious wiring problems
6. The Walbro fuel pump makes sounds like it's working when key is turned on
7. The Injectors have 12v to them with the key "on"
8. According to the EMS, the sensors are all working and there are no errors
I'm at my wits end with this. The car engine turns over will not start. There might be other fuses or electrical components that I've not checked or there might be other mechanical reasons for this.
Please help me with this!
Thanks,
Manuel
Thanks,
Manuel
Originally Posted by timzcat
If the car was rear ended it is possible the puckup on the fuel pump came off from the impact or any number things could have happened. Check for fuel pressure at the fuel rail.
Thanks
duno if u got it fixed yet sometimes their is a fuel cut off after u get in an accedent it shuts the fuel pump off to try to prevent fires.. maby.. i duno sorry just came up figured id throw in my .02
Originally Posted by GOKOU
I figure that was the case. The timing was off. Same thing happen to me on my 00 SI. That was some serious damage. Do check the head bolt cuz they could be loost now.
ahh nice glad u got it going again.
. Oh well.....
Originally Posted by silverEVO8
I think I was lucky. There did not seem to be any damage. The engine has good compression so there is no leaking anywhere.....
bboy_RES
10
Dec 16, 2008 07:39 PM
VRSF Tiago
Oct 13, 2008 05:11 PM
Joshs EVO
Jul 6, 2007 11:44 AM
PorkRoll
Feb 28, 2007 09:36 AM
