1-2 missing gears
Old Jun 12, 2004 | 12:04 AM
The Emperor's Avatar
1-2 missing gears
every time i try to floor it from 1st gear then shift to 2nd at redline..it wont go in!!..someone please help me fix this problem!
Old Jun 12, 2004 | 06:33 PM
BMan's Avatar
Shift out at 6200 and it will go in easy.
BMan
Old Jun 12, 2004 | 06:37 PM
Czubaka's Avatar
Give a slight pause in moving the shifter when you get into neutral. Gives the syncro's a chance to spin up before engaging 2nd.
Old Jun 12, 2004 | 10:19 PM
yea cuz if i shift at lower rpm not redline it goes in...is there something wrong with the clutch engagement?..if i change the clutch line will it help improve..
Old Jun 12, 2004 | 10:23 PM
lil'evil_evo's Avatar
Buy new shifter bushings. Also pick up the under the hood ones as well. This will help a lot.
Old Jun 12, 2004 | 10:27 PM
XRS-Lift's Avatar
online link?
Old Jun 12, 2004 | 10:30 PM
soo to fix this problem...8pc and a 2pc bushing set...and a SS clutch line???
Old Jun 12, 2004 | 10:44 PM
Blitzbaster02's Avatar
no i have all of those, it doesnt fix ****, just makes shifting feel more smoothly.
Old Jun 12, 2004 | 11:03 PM
I can't say it will fix it 100% because I never really had a problem shifting. It just feels so much better will above listed mods. http://www.lancershop.com/clutch.htm
Old Jun 12, 2004 | 11:16 PM
DOOMID@TeamD's Avatar
Former Vendor
shift right at 7k, it will go in....a little under or over and it will get tricky. Alot of it is mental and I had this problem also. Not saying to jam it in but use a little force...it will go dont be afraid to drive the car...
Old Jun 12, 2004 | 11:20 PM
bukhumnoi2000's Avatar
I have the same problem... seems like many people have this issue as well. I personally think it was a design flaw. I have the bushing.... no fixie.. have not tried the clutch line yet. The remedy for me is I don't rev it pass 5K before shifting to 2nd. When I hear the grind it just kills me. If you find something that works for you please let us know. Thanks
Old Jun 12, 2004 | 11:40 PM
ducaticorse's Avatar
That's because the syncros in the Evo ****ING SUCK!!!!!!!!!!!!!!! Along wih the rest of the drive train minus the motor.
Old Jun 13, 2004 | 12:47 AM
umiami80's Avatar
I am fine with it, it goes in fine, just don't be afraid, shift properly..
Old Jun 13, 2004 | 12:53 AM
simevo's Avatar
I shift at 7500 or moore without any problem. I'm using Redline MT90 as well.
Make sure before you shift, don't put any pressure on the shifter until you have pressed the clutch pedal in fully. I know for myself, my hand moves bit faster than my leg and that causes shifting problem from 1-2.
Old Jun 13, 2004 | 06:37 AM
Dr. Fob's Avatar
My thoughts exactly. Even the slightest pressure (hand resting on shifter) may mis-align the cones in the synchronizer. Also, be sure to stomp the clutch pedal all the way before shifting.
