Do I need a fuel pump if................................................ .............
I was just wondering if anyone has had to upgrade the fuel pump if the only mods done were the intake and full exaust (downpipe & cat delete)???? I have not installed the mods yet so if I need to do this I want to do it all at once. Thanks
as long as you aren't turning up the boost any more you should be fine. If you add a boost controler or get a reflash you really should get a pump and consider a fuel pressure regulator so you can get consistant performance.
mrfred
68
Jul 13, 2017 11:22 AM
