ecu reflashing ?
Old Jun 26, 2004 | 07:16 PM
Failed_Senses's Avatar
Originally Posted by hotrod2448
I believe works offers free reflashing back to stock. My question is say you get it flashed have a problem, send the PCM back and get it flashed to stock and then bring it in for work. Is there any way they can check the PCM to see if it has been flashed previously. I know its not honest but it's a "hypothetical" question.
I'm pretty sure they can tell...wasn't there a post about them knowing awhile back or is that the post that was referred to before?
Old Jun 26, 2004 | 07:35 PM
NOVA EVO's Avatar
Originally Posted by sr20det91
If they decide to "read" your ECU they can tell it has been flashed. Just ask JoeyCoats.
Damn...are you serious??? The Powerloader reflash on my Vette was totally undetectable...I got over $2500 worth of work done under warranty AFTER the reflash...I guess GM isn't as militant as about warranty work...
Old Jun 26, 2004 | 08:53 PM
PHILLY EVO's Avatar
Originally Posted by v8killer
philly was that a base flash or custom flash and did you dyno?
IT WAS A CUSTOM FLASH AND GOT DYNO....HERE IS MY DYNO SHEET
Old Jun 27, 2004 | 12:18 AM
NOVA EVO's Avatar
Damn good, dude...you went up 30.2 HP and 39.2 TQ at the wheels...
Old Jun 27, 2004 | 12:38 AM
WannaRace's Avatar
With regards to JoeyCoates, Mitsu said that his ECU was clear of any/all signals and therefore determined that it had been tinkered with/cleared of all messages..
Old Jun 27, 2004 | 01:35 AM
Is there any way to reflash back to stock and keep the signals/messages? Perhaps dump them somewhere before flashing?
Old Jun 27, 2004 | 09:20 AM
NOVA EVO's Avatar
That seems pretty weak...how do they know that it wasn't clean to begin with...or does put "secret" codes in each ECU before it leaves the factory in order to know if it had been flashed??? Then again, if they DO do that, then the codes are either in NV memory, which means that you could read them and store them for later reinsertion, or they are in memory that is erased when power is lost, in which case all you'd have to say is you disconnected the battery for whatever reason. I'll bet the dealer snowed that guy into fessing up about the reflash...you gotta deny, deny, deny...never, ever admit ANYTHING!!!
Old Jun 27, 2004 | 09:39 AM
fabevo's Avatar
deny, deny, deny, ok , i am good with that . so has anybody experienced more than one of these reflashes( dynoflash, xflash or works ). to determine if one is better than another?
Old Jun 27, 2004 | 03:54 PM
nastea's Avatar
i thought it was becuase his name on here was his real name, and we all know mitsu reads this crap, just so they can void warrenties, then put out a press release denying it.
Old Jun 27, 2004 | 07:02 PM
Yea that was a factor too now that I read the post. Who knows...there has to be someway around this...there always is.
Broham
Dec 23, 2009 04:28 PM
hkopenep074714
Oct 7, 2008 02:47 AM
Bawb3
Lancer Engine Management / Tuning Forums
Aug 20, 2008 07:37 PM
edison
Northwest Region
17
Dec 11, 2007 05:09 PM
TurboWill
Northeast Region
Dec 31, 2003 12:34 AM
