UR high flow cat
Old Jun 25, 2004 | 01:44 PM
Az3ar's Avatar
UR high flow cat
I got the ATP kit and I have been doing some serious searches to find what is the best Flow CAT out there that look’s like stock (cops can't tell) and it will flow nice to make my turbo spool better. Test pipe is out of the game because here in LA cops will go down on there knees to check if you have a CAT. I am thinking about buying a UR 3" high flow cat from an EVOm member here on the forums. What do you guys think about it? any better once on the market that look like stock or close and can flow good?? plz help.
Old Jun 25, 2004 | 01:47 PM
siantjab's Avatar
You gotta love when a cop goes down on his knees! j/k
I've heard only good things about the UR high flow cat.
Old Jun 25, 2004 | 02:00 PM
Az3ar's Avatar
Yea me too. However, I know that our stocky one is highflow too so I just dont wana spend money on something that wont improve my spool
Old Jun 25, 2004 | 02:02 PM
tama_mog's Avatar
I can attest that the UR high flow cat definitely helped me spool my stock turbo by maybe 200 rpms. It's blatantly lighter than the stock cat as well.
Old Jun 25, 2004 | 02:09 PM
Az3ar's Avatar
nice man. I am sure it will give me even better results with my bigger turbo.
Old Jun 25, 2004 | 02:11 PM
xchoirboy's Avatar
gruppe-s is supposed to come out with 1. you might want to call them.
Old Jun 25, 2004 | 02:12 PM
tama_mog's Avatar
If you truly wanted no cat but wanted the stealth look, I think there are vendors that sell cats that are gutted out basically....so it's basically a test pipe that looks like a cat.....then I recently learned theres an attachment you can buy to attach onto the test pipe to make it look like a cat. Lots of options....
Old Jun 25, 2004 | 02:18 PM
Az3ar's Avatar
do you guys know who is that vendor?
Old Jun 25, 2004 | 02:20 PM
tama_mog's Avatar
I think road race engineering is the one, almost sure about it.....
Old Jun 25, 2004 | 02:29 PM
Az3ar's Avatar
Just called them. I have to weld it on so I guess that out of the question as well.
Old Jun 25, 2004 | 02:32 PM
tama_mog's Avatar
why is that out of the question? All you do is buy a cheap test pipe and they weld on those pieces for you and it looks like a cat heh. Not that big of a job. Or you could always gut out your stock cat....I wouldn't recommend this but it's an option. Or buy a high flow cat like the UR and gut it out and save your stock in case you need it.
Old Jun 25, 2004 | 02:54 PM
Az3ar's Avatar
I think thats what I am going to do buy the UR and gut it out
Old Jun 26, 2004 | 03:09 PM
BuLocal's Avatar
There are high flow cats that perfectly street legal. You are right about the cops checking here in so-cal.
Old Jun 27, 2004 | 07:30 AM
evo_dadi's Avatar
just check also if the hiflow cat is carb approved also since changing the cat on a new car can get you issues also just in case the cop takes a look at it.since the only time you can replace the stock cat is when it gets damaged
