Just got Dynoed...
Old Jun 26, 2004 | 06:07 PM
ColinL's Avatar
Originally Posted by EVOTEXAS
Well aware, thanks. But what are you talking about 6266?
are you aware of algebra?
HP = torque * rpm / 5252
my assumption--again, almost certainly *wrong* but just to prove a point--that this guy's peak HP and torque occurred at the same RPM. that means we plug his two numbers in and solve for rpm.
315 = 264 * rpm / 5252
315 * 5250 / 264 = rpm
= 6266
Old Jun 26, 2004 | 07:51 PM
RADmitsu's Avatar
Well, sorry to burst your guys bubble, but after reviewing my dyno sheet... here is what i discovered...
I read it completely and it says baseline in blue - 264 - final run - 315...
This is MAX POWER achieved, it does not list torque... Sorry for the confusion...
Old Jun 26, 2004 | 09:07 PM
Fourdoor's Avatar
Not a problem.... what RPM was you power peak stock and what RPM was the power peak after the mods? Also, what kind of dyno? H3ll, just post of the sheets and be done with it!
Keith
PS: Nice feeling to gain 51 HP isn't it?
Old Jun 27, 2004 | 05:42 AM
RADmitsu's Avatar
I don't have access to a scanner... Peak RPM is not listed... The dyno is a DynoJet AWD - i believe that is what Turbotrix has...
The power difference is night and day, it is crazy... i can't wait to get the cams and cam gears installed... The other thing is the intercooler, maybe next week...
Old Jun 27, 2004 | 06:20 AM
evo8power's Avatar
good numbers, but yeah i do agree tourque seems way low. my last dyno was 330whp 360ft lbs....guess thats whjt DYNOFLASH does for you, but nice nonetheless, as long as your happy with it its all that matters bud...
Old Jun 27, 2004 | 08:19 AM
TurbotrixRacing's Avatar
360 ft lbs of torque .. thats alot ..what mods? Very odd to make 30ft lbs over hp's .. Either a boost spike or you should of been making 350hp..
Mark
Turbotrix
Old Jun 27, 2004 | 08:26 AM
evo8power's Avatar
BR-fmic
BR-downpipe
BR-cat delete pipe
JIC cat back
HKS intake
BR MBC
custom DYNOFLASH
but i was overboosting a bit, 25 psi.......
Old Jun 27, 2004 | 01:02 PM
RADmitsu's Avatar
[QUOTE=evo8power]good numbers, but yeah i do agree tourque seems way low. QUOTE]
It wasn't a torque listing... it was max power and baseline...
Old Jun 28, 2004 | 08:09 PM
evo8power's Avatar
huh? then what the heack is the torque?
Old Jun 29, 2004 | 08:19 AM
JoeWalker4G63's Avatar
The torque is not listed. All he has according to his post is that is shows the baseline run and the 315hp run. The printout he got did not list the torque. At least after reading that is what I am understanding.
