will i pass smog???
Old Jun 28, 2004 | 07:48 PM
The Emperor's Avatar
will i pass smog???
would my car be able to pass smog if my setup was..HKS downpipe, HKS Carbon Ti exhaust, Vishnu Xflash, HKS 264/272 cams???
Old Jun 28, 2004 | 07:57 PM
inariv5573's Avatar
Good luck on getting a straight answer. I have the same concern for a 3" high flow cat. I have not to this day have gotten a straight answer. For now, I would say if you still have the stock cat you most definitely should pass.
Old Jun 28, 2004 | 07:59 PM
evo8power's Avatar
smog will be eating my smog, who cares make your car fast enjoy it and dont worry about beating other people unless they call u out first....darn Vishnu kids...
Old Jun 28, 2004 | 08:11 PM
tweakdsm's Avatar
keep the stock cat, swap it when you will go for emisions even hi flow cat might fail, so i would change downpipe back to stock with cat. and leave the catback lower the boost down, all they do is REV REV check the cap, and if they are no CE ligght and thats all, they dont have AWD platforms....
Old Jun 28, 2004 | 08:16 PM
inariv5573's Avatar
Why would he have to change the downpipe back to stock and turn the boost down? He has the HKS downpipe which matches perfectly to the stock cat. High boost is not going to affect the emissions, seeing as all they do is rev it. No boost is produced. Even if it did, the high boost will run leaner than stock, making a cleaner exhaust gas. Dowmpipe shouldn't affect it either, it is just a pipe, there are no emission controls there, if anything it will light up the cat better.
Old Jun 28, 2004 | 08:18 PM
evo8power's Avatar
lol lol i love these people lol lol
Old Jun 28, 2004 | 08:20 PM
inariv5573's Avatar
Old Jun 28, 2004 | 08:26 PM
soo basically swap the downpipe to stock...and the cat then hopefully i will pass??
Old Jun 28, 2004 | 08:29 PM
03venom's Avatar
With the stock cat you should pass with no problem.
Old Jun 28, 2004 | 08:43 PM
alright thanks guys!!!
Old Jun 28, 2004 | 08:57 PM
2GDSM's Avatar
uhhh cams usually means no passing smog.....the rest shoudl be fine...and whoever said leaner means better emissions is wrong....stoich is usually the best emissions....running lean means running hotter and hotter usually means more CO in the exhaust... thats basically a fact... Although, most states dont have AWD dynos so u shouldnt really have a problem passing.
Old Jun 28, 2004 | 10:12 PM
BuLocal's Avatar
Read this thread in the Vishnu forum. Read the first page or two >> https://www.evolutionm.net/forums/sh...highlight=smog
Old Jun 29, 2004 | 07:42 PM
inariv5573's Avatar
How would cams affect emissions? Especially if you are just running 264's.
Khm525
Oct 27, 2015 10:53 PM
Nelson999
Aug 24, 2011 11:36 PM
landis507
20
Nov 7, 2009 03:09 AM
kungfugirl
Apr 22, 2008 07:32 PM
justin44
Feb 5, 2006 10:04 AM
