TPR Magazine EVO8 exhaust shootout.
The downpipe and cat were both bone stock on the car. This was a catback test only.
Love to see the results with the entire system on the car.
David Buschur
www.buschurracing.com
David Buschur
Dave,
I'm very interested in the Magnaflow version of your exhaust. Could you or somebody comment, on how to build an exhaust system from the muffler back? The stages I would like to go are basically 1.) a catback then, 2.) replace the stock cat, then 3.) replace the downpipe.
Can your exhaust system be built up this way?
Thanks,
jcnel.
Thanks,
jcnel.
Originally Posted by jcnel_evo8
Dave,
Thanks,
jcnel.
Thanks,
jcnel.
Thanks, that is some really good information. I suppose I feel kinda bad that I'm not as flexable because I 'live' currently in Utah, and have 'very' limited resources for tuning avaliable, when the parts are ready to be purchased. There is a good SCCA crowd around, so I can kinda bank off of their support.
Now...if I got the SCCA Legal Catback now, how much (if any) 'tuning' would I have to put into the car right now?
Thanks,
Cheers,
jcnel.
Thanks,
Cheers,
jcnel.
Not wanting to sound 'too' technical, and picky...yet will I have any problems with my Air/Fuel mixture? I live at fairly 'high' altitude and like to keep the car in a 'good' state of tune...
When I change something its usually backed up with a tune along with it. Yeah...I'm kinda picky in this regard, but I have probably some better tuned sportbikes because of it.
Cheers,
jcnel.
Cheers,
jcnel.
High elevation usually means you are going to have to tune the car much leaner than we normally would. Wait, not leaner, just have to pull a larger amount of fuel out to get it to normal AFR's. Make sense?
This can be done easily with the AFC.
David Buschur
David Buschur
Thanks Dave,
The feeling I get is it seems I'm in need of an EVO tune after getting the cat-back. I was kinda hoping the stock EVO programming wouldn't be 'too' far off, and I could run a cat-back...but after modding four new vehicles the only ones that seemed to run 'right' after the muffy. install were a couple of 4 cyl. sportbikes with just slip-ons on them.
Also...part of my justification is I don't want to run the EVO richer than it already is set at. I assume a high flowing muffy system is probably going to make the equation richer.
Thanks for the great info. tho!
Cheers,
jcnel.
Cheers,
jcnel.
Yes, you can get the SCCA with Magnaflow for $450, not shipped for $470, it would be $505 with shipping, oversized and two boxes.
You do not need a re-tune from just an exhaust change on an EVO.
David Buschur
David Buschur
David Buschur
David Buschur
well crap i just paid $525 instead of $505 for my BR catback with magnaflow. ah well
Hitting this topic again to get it up to the top so it can be found.
Thanks,
David Buschur
Thanks,
David Buschur
