Cams and Break-in Period
Hey all:
I am curious what you think a proper break in period is for a new set of 272 in/ex cams, along with head studs, injectors, and fuel pump?
any thoughts or ideas would be great.
Thanks
Thanks
Works recommends breaking them in for a minimum of 200-300 miles, whereas Vishnu said no breaking in is necessary.
So, depends on who you asked.
I just take it easy for a few hundred miles.
When I had my cams installed i was told not to let the car idle and to rev it to about 2500 rpm and hold it there for a minute then to go drive normal with out hard revving for about 100 miles
I believe that cams alone don't require much of break in period, but if you change the valvetrain, then it would make sense that you would have to break in moving springs and new valves/retainers........ well at least it makes sense to me.....
Originally Posted by Quickshift
Cam break in = 15min of holding your rpms at 2500 rpms
I respect Shiv as a tuner, but not a nuts-and-bolts mechanic by any means.
Originally Posted by ColinL
this is the old standard and still works just fine. do this on regular oil, NOT synthetic, and change your oil and filter after a 100 miles or so.
Ya no need for regular oil, I did mine just fine off of synthetic. I even opened my head back up to re check the cams and make sure all the bolts where in proper torque spec, which they where.
Originally Posted by mayhem
Why use regular oil? Wouldn't the springs be the only thing that need to 'break in' or readjust?
everyone doing a cam job should read this:
http://www.cranecams.com/?show=faq&id=1
ignore the parts about pushrods, LOL. the rest is very applicable.
note the part where they say DO NOT break in at a steady RPM. this is true. also, do not rev the nuts off the engine.... ever while in neutral, to be honest, but especially during cam break in.
