PLease read if you have installed your own Evo Clutch.
2 things you to know. When you get the axles out, there are splines sticking out of the trans. take a 12mm bolt screw it to the end of the male part of the splines. Then take a slide hammer (works best) and yank em out. Then you can seperate the t-case from the trans. The t-case will not come out of the car with the trans still in.
The other thing is you can't get the trans off of the motor without releasing the TOB first. good luck
