gas issue!! (HELP)
Old Jul 8, 2004 | 05:09 PM
gofaster87's Avatar
I get 101 trick racing fuel for 4.69 by the gallon or discounted when i get 55 gallon drums. Sherman Williams sells toluene for 5.XX per gallon when u buy a 5 gallon jug of it. Here is a mixing chart for 100 octane and 91. Before I used strictly 101 octane for the evo I was mixing 2 gallons of Toluene with 12 gallons of 91 octane. Worked great.
Old Jul 8, 2004 | 05:45 PM
bpclements's Avatar
If you are mixing Xylene or Toulene in excess of 10% I would recommend adding in a lubricant such as Automatic Tranny Fluid. Also, gas companies already use these chemicals to raise the octane level of gasoline to begin with. As long as the aromatic content (Xylene or Toulene) of the mixture does not go above 46% I believe it is, it is still defined as gasoline and perfectly safe to use in your car. Considering that the proper amount of lubricant is added to the mix in addition to the chemicals.
Here is a fuel blending calculator.
Old Jul 8, 2004 | 06:10 PM
The Emperor's Avatar
would 100 octane void my warranty?
Old Jul 8, 2004 | 07:02 PM
batty's Avatar
nope
Old Jul 8, 2004 | 07:13 PM
SterlingEvo's Avatar
wow... so much easier to live in va and buy 93 or 94 at the pump. But I guess the nice weather and beaches of Cali are worth it? Chris?
Old Jul 8, 2004 | 08:00 PM
Eva01's Avatar
Down here in South FL, 93 Octane is available everywhere. I am trying to find a place that sells 100.
Eva01
Old Jul 8, 2004 | 10:01 PM
Az3ar's Avatar
I lived in Nova (VA) for 6 years. Rain and ****ty weather everyday. the best thing is Sanco 94 gas for $1.97 every day in McLean. However I never found 100 there of the pump. Here in Ca 100 is of the pump for $5.19 . (crazy). however, the weather the beach is well worth it.
Old Jul 8, 2004 | 10:14 PM
Jaylenospoolboy's Avatar
rrrrrrrrrrrrrrRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRBBBBA NG!.............................tput tput tpuuuuuuut......clunk.........silence in the engine bay.
Just know what your are doing... .
(Heat and) detonation will kill your engine so mix it right or don't turn up the boost.
Old Jul 8, 2004 | 10:30 PM
1QWKEVO's Avatar
Originally Posted by chrisw
If you look at the cost of doing what you suggest, the 100 octane gas is pretty cheap....
The cost of what i'm suggesting is $7.99 for a tank or like $8.99 for the MAX booster .... a min of 3-4 gallons of 100 octane is needed to make 93-94 octane... which in my eyes is 15-20 bux
Old Jul 8, 2004 | 10:43 PM
Az3ar's Avatar
I boost 23~24 psi but I run 94 gas all the time now.
Old Jul 8, 2004 | 10:52 PM
ezhangin's Avatar
100 octane
ive never used 100 octane before but over here its $3.50 a gallon, LOL
Old Jul 8, 2004 | 11:38 PM
SinCityEvo's Avatar
76 stations here in Vegas have 100 at the pump for 3.95. I put 3.5 gallons, then fill with 91. Much easier to pump it right in and be on your way. I totally feel a difference over just straight 91.
Old Jul 8, 2004 | 11:44 PM
value's Avatar
Sucks to be me !!! 76 sell's 100 octane for $6.00 a gallon in hawaii
Old Jul 9, 2004 | 06:53 AM
the 76 station is a block away and the 100 octane is $5.39..it used to be $4.99..WHAT THE HELL IS GOING ON WITH THIS WORLD?!?!?!?
Old Jul 9, 2004 | 08:52 AM
SinCityEvo's Avatar
^ That's a huge price difference between So Cal and Vegas for 100. I wonder why?
91 gas is only within a few cents of each other.
