BR440 questions
Old Jul 12, 2004 | 01:52 PM
propellerhead's Avatar
Cool! That almost sounds like some disimilar metal corrosion between the aluminum of the MBC body and the steel spring. Might not hurt to shoot just a tad of WD40 in there.
I'd like to check out your upgrade if we both meet up at the Crossroads meet in Springfield sometime. Maybe in a couple of weeks. How did you tune for the new turbo?
Old Jul 12, 2004 | 02:01 PM
nastea's Avatar
its not tuned atm.
Old Jul 13, 2004 | 04:37 AM
nastea's Avatar
i got it to hold boost ! it was the boost controller however now i have the issue that the aftermarket BOV i'm using (Turbosmart) starts futtering on acceleration... (PoS) anyway, it spikes up to like 23, and then in a split second it drops to 20 and holds.
Old Jul 13, 2004 | 06:04 AM
evo 8 ya's Avatar
cool man I wana ride.
Old Jul 13, 2004 | 06:18 AM
nastea's Avatar
i gave evo1ved a ride last night
Originally Posted by aol
evo1ved: dude your evo has crazy pull
Old Jul 13, 2004 | 07:14 AM
David Buschur's Avatar
nastea,
Glad to hear you fixed the problem.
David Buschur
www.buschurracing.com
Old Jul 13, 2004 | 07:15 AM
nastea's Avatar
yeah thanks dave, should it be spiking to ~23 or is that how long it takes for the wastegate to open? its like a split second it jumps up then goes down to 20.
Old Jul 13, 2004 | 08:04 AM
The spike is more than likely in the boost controller. That BR440 kit hits pretty hard, so as long as it is a split second I wouldn't worry about it.
David Buschur
Old Jul 13, 2004 | 08:09 AM
nastea's Avatar
yeah i wasn't too worried about it, and i figured it might be the hallman... i'm gonna end up getting a new one, and yes the 440 hits hard as hell
after i fixed the BC issue last night, and test drove it, it was boosting to 23 psi, but i think that the spring might have gotten some "memory" from teh stock setup i have before, so i might just put in a new hard spring from hallman, and see how that effects it.
But the difference from 15 psi to 20 is huge
Old Jul 13, 2004 | 09:12 AM
That turbo spool up is super nice, not much more lag than stock at all.
What all is done to your car? I looked through our database here and see the full exhaust, just wondering what else you have.
David Buschur
Old Jul 13, 2004 | 09:18 AM
nastea's Avatar
272's, arp head studs, your amazing turbo, full 3" TB, hallman bc, hks racing suction. thats the basics, i know i need to ditch the intercooler pipes and the intercooler, and i think thats my next upgrade.
Spool is amazing there is 10 PSI at 3000 and then full flowing hard hitting 20+psi at 3500
Old Jul 13, 2004 | 09:24 AM
batty's Avatar
man alot of issues popping up with these BR turbo kit installs but seem to have nothing to do with the turbo kits themselves.
Old Jul 13, 2004 | 09:30 AM
Aaron@Dynoflash's Avatar
yeah i have no issues with the turbo....
Old Jul 13, 2004 | 09:40 AM
GottaGoFaster's Avatar
Which Turbosmart BOV are you using?
Old Jul 13, 2004 | 09:43 AM
nastea's Avatar
dual port
