Twin turbo EVO???
Old Jul 21, 2004 | 04:38 PM
Abu_Dayya's Avatar
Question Twin turbo EVO???
I know this might sound stupid, but did anybody try to do a tt 4 clynders?
Old Jul 21, 2004 | 04:39 PM
EVOMIZ's Avatar
lol
Old Jul 21, 2004 | 04:42 PM
MalibuJack's Avatar
I'm sure its been done before.. But I suspect the reason you haven't seen it is due to the confines of the engine bays on most cars, and likely any experiments that had been done probably didn't offer the desired results.
Old Jul 21, 2004 | 04:47 PM
Rez90's Avatar
It's been done with DSM's before....never had any results to show any significant advantage...
Old Jul 21, 2004 | 05:03 PM
marksae's Avatar
I believe Doug'd Dynopower built a twin T25 turbo'd 2g a few years back. It didn't seem to perform any better than a 20g or so. I think he did run 11s with it.
Old Jul 21, 2004 | 06:42 PM
lancerpartstrad's Avatar
only advantage would be spool up, but BB turbos kind of have that problem beat anyway
Old Jul 21, 2004 | 06:48 PM
Ichiban's Avatar
There was a huge discussion on DSMtalk some time back. I believe there was even some testing...with, as stated above, negligible results. The semi-consesus was the no matter how many turbos you have, you're still running the set boost...15 psi is 15 psi....not 30 cause there're two turbos. Equal pressures flowing the same direction from multiple sources do not compound.
Old Jul 21, 2004 | 07:21 PM
tweekscratch's Avatar
you could go w/ the RX-7 route and do sequential turbos. That would allow for earlier boost response w/ the bigger second coming online later. The thing is that it was not particularly reliable. Most serious RX-7 tuners either switched to a single large turbo.
It seems that the EVO could use a little help below 3500 RPM, but I don't think the added complexity of a second turbo is the answer. An ECU upgrade and a cam would probably be a better (and cheaper) approach. But my application (autocross) is probably different than yours.
Old Jul 21, 2004 | 07:29 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I think the perfect engine for the twin turbo setup is the Subaru boxer. One turbo on each side sitting right off the head. Less piping to the turbo, so it should be pretty effecient. I believe they do a twin turbo set-up on the B4 (JDM Legacy)
Old Jul 21, 2004 | 07:30 PM
MalibuJack's Avatar
There's technology available that would be better suited if you want to lower the spool.. I've been working with a Titanium wheel turbo (and OE Japanese unit)
I've seen one other interesting application of a twin turbo setup on a truck, it is a double compressor, the second turbo compresses the air AGAIN after its compressed by the primary turbo.. I don't know if the experiment ever worked out though.
Old Jul 21, 2004 | 07:43 PM
You mean a supercharger/turbocharger combination? I've seen that too, it worked out pretty good.
Old Jul 21, 2004 | 07:50 PM
4Gsixty3's Avatar
twin turbo on our cars??!! WHY?
Old Jul 21, 2004 | 08:26 PM
inline4g63's Avatar
Twin charge
Old Jul 21, 2004 | 09:01 PM
dapaspy's Avatar
JDM Legacy is sequential turbo believe it or not. I know because my best friend had one here in Cayman. It uses the IHI VF18 and VF19 turbos.
Old Jul 21, 2004 | 11:17 PM
trinydex's Avatar
putting twins on a boxer isn't really a new idea, since the boxer is basically like a v engine it's always "easier" to put twins on a v engine setup... cuz otherwise tubing gets all complicated.
