Rod Bolt Install.
Old Oct 5, 2008 | 07:02 PM
Dapper Dan's Avatar
I installed some arps and I didnt have any problems with them. Easy install....
Old Oct 5, 2008 | 07:26 PM
mchuang's Avatar
Did you remove the oil pan and just do it with the head still on the motor?
Old Oct 5, 2008 | 08:14 PM
Steveevo9's Avatar
Dapper Dan can you tell us how you did this procedure please?
Cheers Steve
Old Oct 16, 2008 | 03:00 PM
bboypuertoroc's Avatar
Veteran: Army
Bump.
Old Oct 16, 2008 | 07:29 PM
StreetThisEvo's Avatar
I installed arp rod bolts on my engine this summer and have put 4k miles on them thus far. I have not had a single issue by doing this. I made about 200 passes this summer and the car is strong as can be.
Old Oct 17, 2008 | 01:05 AM
Steveevo9's Avatar
What procedure did you use, engine out of vehicle or dropping the oil pan? This is what most of us want to know, tia.
Cheers Steve
Old Oct 17, 2008 | 01:08 AM
yellowevo82's Avatar
i def suggest this, i had rod bolt snap and bearing failure which caused me to blow my motor...
Old Oct 17, 2008 | 10:27 AM
COL Knock's Avatar
It would be hard to distinguish between a rodbolt snapping causing eng failure or engine failure causing a bolt to snap.
After all, the only thing that can cause a bolt to snap in a healthy engine is 9000 rpm or a defect or careless bolt stretch
Old Oct 17, 2008 | 10:35 AM
Dapper Dan's Avatar
Cheers Steve
removed the downpipe, starter, oil pan and removed and installed them one at a time. Torqued the way the card that comes with the arp studs says too.
Old Oct 29, 2008 | 01:59 AM
Steveevo9's Avatar
Thumbs up
Thanks very much Dapper Dan
Cheers Steve
Old Oct 29, 2008 | 08:51 AM
mchuang's Avatar
I assumed you just reused the same bearings?
Old Oct 29, 2008 | 09:13 AM
C6C6CH3vo's Avatar
Didn't guage them for one torque? Might be able to get around this if replacing same parts but those might have a different clamping load.
How easy did the OEM bolts come out?
Old Oct 29, 2008 | 09:51 AM
Dapper Dan's Avatar
yes I didnt even pull the bearing caps off.
[QUOTE=C6C6CH3vo;6287767]Didn't guage them for one torque? Might be able to get around this if replacing same parts but those might have a different clamping load.
How easy did the OEM bolts come out?[/
QUOTE]
they pop right out
Old Oct 29, 2008 | 10:33 AM
I did mine with the engine in the car and just dropped the pan.
Old Apr 5, 2009 | 01:14 AM
lillev23's Avatar
edit.
