Clutch is gone!!!
Old Jul 29, 2004 | 07:58 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
yeah ...its damn near like stock....if you have leg muscles to walk you will be fine...lol
Old Jul 29, 2004 | 07:59 AM
evodave's Avatar
and also i do agree that lightened flywheels make a huge diff....at least when your factory one weighs 25 + lbs...thing is ours weigh much less....so not much difference.
Old Jul 29, 2004 | 08:05 AM
EvoJimbo's Avatar
Definitely heavier than stock.
Old Jul 29, 2004 | 08:06 AM
tweakdsm's Avatar
i have the act 2900 clutch with a fetanza flywheel, and a clutch line...awesome set up ...under $900.00 just for the parts i listed above...
Old Jul 30, 2004 | 07:59 PM
[TYPE]SS's Avatar
how's the exedy clutch pedal feels comparing to stock?
Old Jul 30, 2004 | 09:00 PM
Wizard_of_Evo's Avatar
i have the twin and it is slightly heavier, but not crazy. takes a little getting used to, but definatley streetable. plus, it will take some serious abuse.
Old Jul 31, 2004 | 12:00 PM
GOKOU's Avatar
Did you do the install yourself or took it to a shop?
I heard AMS was good? Anyone done a clutch install there? Other recommended shop around that area?
Thanks.
Old Jul 31, 2004 | 12:10 PM
Rez90's Avatar
I have the exedy twin disc. it's fantastic. had some chatter when i first got the clutch...but after a couple of weeks it's gone... it still makes noise when engaging...but thats just the nature of the clutch.
as far as clamping...rediculous. the pedal feel is just like stock...but when i slip it at 6k, all four wheels light up instantly. i have never had any kind of smell or slipping with this clutch.
based on all of the clutches i went through on my DSM's (ACT, centerforce, RPS), the exedy outperforms them all...by far. in my opinion, it was worth every penny i paid for it.
Old Aug 13, 2004 | 06:39 AM
GOKOU's Avatar
Just got the ACT clutch install yesterday. Pedal is slightly heavier then stock but nothing to complain about. Definitely better but I need to adjust to it. Stall a few times in first already.
Not sure if it is normal but I get a rattling/vibrating sound kinda like a loose exhaust when in first gear at around 2000 rpm. Hopefully it'll go away after the break-in.
Hope everyone is doing good!
Old Aug 13, 2004 | 07:49 AM
raced_EvoVIII's Avatar
I noticed a little screeching like noise under load at first when breaking it in but have talked to several others with the same type of clutch and its very normal. It only lasted like 100 miles tops, and now its perfect.
Old Aug 13, 2004 | 09:20 AM
GOKOU's Avatar
Thanks for the comfort. I can't wait until the break-in is over so I can go back crusing and look for SRT4 again Off to the track to see the 1/4 time as well.
Old Aug 13, 2004 | 09:34 AM
93civEJ1's Avatar
have fun....i still am using my stock clutch with 22k on the car...its starting to feel sucky, but when the time comes i will be using the RPS or ACT as well. Congrats man.
