What EGTs do you see?
Old Aug 24, 2004 | 09:38 AM
wangspeed's Avatar
Stage 0 Vishnu (3" turbo back) on 93 octane. I have seen the gauge peak at 960C. Running the stock program results in approximately the same temps. No audible ping from inside the cabin. Tried resetting the ECU to see if I was in a high knock map, and hence retarded timing, but that didn't lower them either. Car feels extremely strong, but the EGT readings are just sky high.
Boost gauge is reading a peak of 22.8 or so, and tapering to 18.8 by redline. Stock BPV.
We're going to hook up the wideband and see what's going on with afr. The probe is located very close to the port. Within 2" of port #2. Pictures attached.
Warren
Old Aug 24, 2004 | 09:41 AM
naucrx's Avatar
My EGT Probe is located on runner #1 about 5 inches from the block. The highest EGTs I've seen is 850 C. But normally it is between 800 and 820 C at WOT. Highway crusing is around 700 C.
Edited: spelling
Old Aug 24, 2004 | 09:43 AM
wangspeed's Avatar
Everyone else seems to have their probes far from the port. Far is relative, but mine is CLOSE. I'm guessing the mixture is still on fire on the way out of the port, hence the sky high reading close to the head.
Old Aug 24, 2004 | 10:37 AM
Bryon @ Quantum's Avatar
I suppose it depends on calibration, etc and whatnot but we always put the probe where your pic shows. We never like to see much over 900; especially on a stock motor.
Mark
www.Quantum-Racing.com
937.642.5400
Old Aug 24, 2004 | 10:50 AM
Originally Posted by stvbreal
Running a bit rich you mean. I see around 1350f to 1400f. I need to lean this pig out.
You cannot go simply by EGT's. EGT's are also affected by ignition timing, etc. Leaner and less timing BOTH give you higher EGT's. It is more something where you need to have it tuned professionally (against wideband, knock sensor, OBD2 scanner, etc.) and then note if the EGT's change from the time you tune, etc.
Mark
Old Aug 24, 2004 | 10:57 AM
WannaRace's Avatar
Ah yes, rich Thanks.. *edited*
Old Aug 24, 2004 | 11:01 AM
WannaRace's Avatar
I had AMS install my EGT and they put it in runner #1, maybe an inch away from the block..
Old Aug 24, 2004 | 11:09 AM
wangspeed's Avatar
I tried running the stock program too, and it resulted in in a peak of 950C as well. Idle settles in around low 600. Highway in 5th can be around 750C to 850C depending on speed.
Warren
Old Aug 24, 2004 | 11:47 AM
Mistasparkle's Avatar
what if your EGT is AFTER the turbo? how would that affect my readings up or down?
Old Aug 24, 2004 | 12:35 PM
WannaRace's Avatar
Temperature readings would typically result in lower EGT's, ie. not as accurate
EVO8LTW
Sep 8, 2011 08:34 AM
rt turbo
12
Sep 1, 2010 09:24 PM
Enisada
Mar 31, 2009 12:09 AM
Chabada15
31
Jun 12, 2008 07:01 PM
NRG
Aug 17, 2004 08:23 PM
