What EGTs do you see?
Old Aug 3, 2004 | 05:32 PM
bbbwrx's Avatar
My EGTs are pretty high(i think) I am getting up to 1600 degress before I start backing off. I hit 1700 degrees once so I know I can go higher. I have a turbo back exhaust and a boost controller(set at 20psi). Anyones else seeing this high of EGT's?
Ben
Old Aug 3, 2004 | 05:34 PM
bishiboy's Avatar
I don't get above 1500. 91 octane, 11:1 afr, 20-5psi
Old Aug 3, 2004 | 05:41 PM
jemm's Avatar
where do you guys have the thermocouple placed?
Old Aug 3, 2004 | 05:43 PM
bbbwrx's Avatar
I don't get it. I run 91 20psi. Maybe I need to get a wideband. This is just the excuse to get a UTEC and Tuner.
Ben
Old Aug 3, 2004 | 05:49 PM
bbbwrx's Avatar
Cylinder number 3
Old Aug 3, 2004 | 05:51 PM
jemm's Avatar
I don't have an EGT gauge, but know of someone with an Ev0 8 with one. I will try to get her peak reading.
We use 90 Octane petrol.
Old Aug 3, 2004 | 05:54 PM
TampaTurbo's Avatar
I hope you are talking about F and not C.
ez76's Avatar
I run Vishnu stage 1+.
On a race gas (100 octane) tune, I never see more than 810C at WOT in 5th gear.
This is measured from a Defi EGT probe in cylinder 1 of the exhaust manifold.
Old Aug 3, 2004 | 05:59 PM
Bluesmaster's Avatar
Danger zone is above 900C -- 1650F. Mine peaks at 900C. 11.3 a/f 20 psi boost-93 octane. Greddy memory gauge egt probe in cylinder 1, DNP header.
Old Aug 3, 2004 | 06:09 PM
kevo's Avatar
Bluemaster, I got the DNP from quantum also. can you PM me how to tap the EGT sensor to the manifold? Thanks.
Old Aug 3, 2004 | 09:13 PM
bbbwrx's Avatar
I better be talking about F because if that was C My engine would eb just a blob of metal on the ground
I have hit the peak while going up a canyon at solid 20 psi for an extended amount of time. I know i was putting strain on it I was just making sure others were getting the same readings. Because they did scare me when they got that high. Thanks for your help.
Ben
Old Aug 24, 2004 | 06:46 AM
Bryon @ Quantum's Avatar
call me Ill talk you thru. it on the phone
Bryon
www.Quantum-racing.com
Old Aug 24, 2004 | 09:12 AM
Reignman's Avatar
Before I put cams in the highest I would see was 880-900c. With HKS cams the highest I have seen is about 820c
Old Aug 24, 2004 | 09:24 AM
WannaRace's Avatar
I only see about 12-1300F at WOT max...Running a bit rich?
Old Aug 24, 2004 | 09:31 AM
stvbreal's Avatar
Running a bit rich you mean. I see around 1350f to 1400f. I need to lean this pig out.
