Exedy sliping
Old Aug 5, 2004 | 09:52 AM
nutnbutturbo4's Avatar
Exedy sliping
I put a Exedy single disc and flywheel in my Evo Feb this year. And already started slipping. I go out and buy a $1000 clutch setup and 6 months later it starts slipping. The is mainly used for hwy but little racing now and then..... but you figure you buy performance parts and then take it easy and they fail faster..... I Called RRE and they suggested ACT...... The Exedy clutch was what they put in their Greddy Evo and he said it failed after the first week it was in.... And all they is problems with Exedy....... so i guess we'll see....... One good thing i have not thrown a p0300 code for over 250 miles
Old Aug 5, 2004 | 09:57 AM
Stinkapuss's Avatar
The Exedy single disc sucks.
Hooptie157's Avatar
See that why I spent the extra dough to get the Cusco Twin plate. I figured do it once and do it right.
Old Aug 5, 2004 | 09:59 AM
Stinkapuss's Avatar
Did this cause your t-case to go or was it something else?
Old Aug 5, 2004 | 10:16 AM
Hooptie157's Avatar
Good question and I don't know the answer YET. Its being taken apart by TeamRip as we speak. I'll give you ALL an answer once I find out.
Old Aug 5, 2004 | 10:38 AM
mits has been making the Evo for 8 generations and seems they cant put in anything to hold the power that just sucks..... then when you finally get a clutch to hold t-case fails or some thing else
Old Aug 5, 2004 | 10:44 AM
Bom's Evo's Avatar
my thoughts exactly...if i was rich i would've gotten the ats one...but cusco is the best of both worlds...good compromise.
Stinkapuss's Avatar
Yes, keep us updated because I already spent enough money on clutches and the last thing I need right now is to spend 2k on a f-ing t-case.
Old Aug 5, 2004 | 11:01 AM
yea the ats is a great set up. but really pricy.... a friend of mine put in the HKS twin disc. then while he was at the track. either ceter diff or t case went out.... it made the front wheels lock up like lsd which could be a bennifit at the strip but he said it made the turning radius suck even more..... and then you get the tires streeking around a turn. he put it all back to stock and it now sits at dealer.. and they want $4000 to repair.....
Old Aug 5, 2004 | 11:09 AM
EvolvedfromaWRX's Avatar
exedy twin suckas
Old Aug 5, 2004 | 11:16 AM
what are some opinions on a clutch set up.....
Old Aug 5, 2004 | 11:19 AM
italianowrx's Avatar
Hyper Single
Works fine for me, had it in for 6 months making 300awhp....
The Twin i'm sure would be nice, but this seems to be holding ok...
C
Old Aug 5, 2004 | 11:24 AM
RRE recamended ACT 2900 psi plate and a HD single disc so Ill try it out with my exedy lightend flywheel
Old Aug 5, 2004 | 11:43 AM
evo 8 ya's Avatar
did you take out the restrictor? If not that's your problem
Old Aug 5, 2004 | 11:48 AM
Az3ar's Avatar
go twin disc and you will be fine and remember its how you drive the clutch
