RVM intercooler pipe kit evo8????
HELP!!!!!!!!
Just got the pipes today, I hate the aftermarket parts install directions there either in Japanese or have install instructions like the ones for these pipes.
Step 1 remove stock pipes.
Step 2 replace with new pipes.
Can anyone tell me where the special silicon pipe called the Turbo Hump-Hose goes
...be nice
I looked at the pics and don't see it in any of them, its the pipe with the hunchback in the middle...
...be nice
From most of the intercooler pipes that I've seen and worked with, the hump hose usually goes on the joint between the upper ic pipe and the throttle body.
Originally Posted by XxBLACKMAMBAxX
Any power gains noticed? 1/4 mile before and after, dyno #s???
i was the 1st to put these pipes on. they are really nice, and stay very cools with the new fmic. fitment is great. looks are great. i noticed a bit in performance and a much faster spool, but i had a 3" upper ic pipe before i replaced it with these. so i can tell you over stock. btw, DO NOT USE A 3" IC PIPE UNLESS YOU RUN A REALLY LARGE TURBO!
sounds good... I'm thinking about gettting these... But the Racemax Pipe Kit looks better and is around that price range.... but you have to get a small battery kit also... Thats what sucks.... debating......
