Those running HKS 272's with no gears
Originally Posted by 93civEJ1
Is it the SAFCII that you have?? Thats what I have, but hopefully I will experience the same that you say. Are there any certain type of settings you are running on the AFC to make it not stall??
sweet, yeah All i have it hi throttle settings in mine as well, but i may zero those out and reset the ECU when i go to do the cams. Will see how it does zero'd out, and then will apply my same hi throttle settings i am running. Maybe I will be lucky as well.
yeah, once the car is running closed loop, the ECU actually learns and compensates for cams and larger fuel injectors. Adjusting the LO-TH settings at idle really are for getting the car to idle when the car is cold (when you first start it for the day) before the O2 sensor has warmed up to the point where it will run in closed loop... For the first few seconds when you start the car (whether its warm or cold) it runs in open loop until the ECU completes the O2 sensor test and its warmed up.. Thats usually when these settings are needed.. This applies to almost any EM solution that retains the stock ECU.. Flashes are able to adjust the default trims and open loop maps to always compensate for this where the piggyback devices alter this externally..
yeah...thats what makes the Lo throttle settings and trying to fix idle with the SAFCII is worthless. Anything you adjust in closed loop the computer will adjust for. You can test this by just idling and adjusting the lo throttle settings around 900rpm or so. At first you can tell you either fattened or leaned, but then the computer does its thing and its back to normal even though the settings are still in the AFC. Im just more concerned with stalling, I dont really care about loping idle.
merlin00069
Apr 27, 2009 08:56 AM
