2G rods and pistons in Evo??
Old Aug 31, 2004 | 11:00 PM
USP45's Avatar
I was told a few days ago that the DSM 2G rods and pistons are the same as, or will work in the Evo's 4G63. If this is so then why are a bunch of shops selling Evo specific rods and pistons? Does anyone know?
Old Sep 1, 2004 | 12:09 AM
marksae's Avatar
They will not work. The valve reliefs won't match. Both engines rotate clockwise, but the intake and exhaust valve locations are flipped. The valves and reliefs are not the same size.
Old Sep 1, 2004 | 12:31 AM
EVOVII_SWE's Avatar
As far as I know rods will work but pistons won't, and the reason for that is as described above ^
Old Sep 1, 2004 | 06:24 AM
Crazy4Cars's Avatar
well, I have 2 road race evo6 customers and we use the 2G 22mm piston pin.
Old Sep 1, 2004 | 10:41 AM
USP45's Avatar
You use the 2G 22mm piston pin, but do you use the pistons or are they custom made for you? And this may be a stupid question, if so then just bare with me, but why could you not just turn the piston around 180 degree's? I do not think that it would know the difference and then the reliefs would be in the correct place. The reason I ask is that every now and then I see an add on eBay offering a rod and piston kit for around $700 including rings, bearings ect. Just curious.
Old Sep 1, 2004 | 11:57 AM
Crazy4Cars's Avatar
we use standard off the shelf pistons from JE or Arias. When I mentioned 22mm is because the evo and the 2g dsm both are 22mm, the first gen is 21mm.
Old Sep 1, 2004 | 07:59 PM
wreckleford's Avatar
I was told the valve relief argument before but I don't beleive it anymore. A friend has an Evo III that blew up and on the advice of his mechanic they installed Evo VII pistons. I thought it would not work because of the valve releifs being on opposite sides, but it has been up and running for a few weeks now without any problems (i.e. piston to valve contact).
Old Sep 1, 2004 | 08:01 PM
The piston wrist pins are not in the exact centre of the piston. If you spin them around, the offset will be on the wrong side.
Emit_1
Dec 26, 2016 12:46 PM
Aniel
Feb 13, 2016 02:21 AM
krkline2gdsm
13
Dec 16, 2008 08:44 PM
Rau
14
Sep 23, 2005 07:56 AM
airtreking
19
Mar 29, 2004 08:42 AM
