Exactly how much boost should I have?
Old Sep 9, 2004 | 09:01 PM
get faster's Avatar
Question Exactly how much boost should I have?
After having some fuel cut problems after installing a k&n typhoon intake and having my tech 'turn down' my boost by making an adjustment to my waistgate I've solved the problems by replacing my original intake.
Trouble is that I read at http://www.machevo.com/gofaenup.html that the evo runs 19 psi of boost right from the get-go. I was trying to adjust the waistgate back to original and remember the tech saying that he turned it down 3 times. The problem is when I turned it back 3 times my gauge (not boost gauge by mechanic's gauge) reads 12.5. I tested the car and I dont have any fuel cuts again and its running ok. I dont know if it's in my head but I feel like its not as fast as before the mess of intake installation.
Can anyone tell me with certainty how much boost I should set this thing to? I really dont wanna mely anything so the advice you give should be from knowledge and experience and not hearsay.
Also, I have a blitz power meter sj to install but the dang thing is in Japanese. anyone with directions that can be scanned and emailed?
Thanks in advance for your responses.
btw, I've an evo 7 right out of Japan.
Old Sep 11, 2004 | 07:46 AM
get faster's Avatar
Hey Guys,
I see many reading the post but I need some replies. 99% of you know more about this car than I do so Ppuuulleease gimme some answers.
Muy Thanks
Old Sep 11, 2004 | 08:11 AM
Dyno4mance's Avatar
If the wastegate has been adjusted to release at 12.5 PSI then your car will feel a lot slower...It sounds like the tech went too far with the adjustment..
Do not use a fuel cut defender as a solution to this problem
My 2yen
Old Sep 11, 2004 | 08:40 PM
get faster's Avatar
Thanks Dyno4mance,
I've put back my original intake and everything's fine with the car. It's just that the technicial thought he was helping me out (when the fuel cut was a problem) by reducing the boost at the waistgate. I just want to go back to where it's supposed to be untill my excede arrives. I dont want to over boost just yet.
I dont intent to use any fuel cut. I have no need to. all I want to do is reset my boost. Should I just go ahead to readjust the waistgate till my boost gauge reads 19?
opusman
Oct 24, 2012 01:29 PM
AC80
Feb 28, 2012 07:23 PM
cec12789
16
May 30, 2011 11:37 AM
avengerhed
For Sale - Cars For Sale
Sep 10, 2005 10:33 AM
Autumn Tactics
Nov 6, 2004 10:14 PM
