View Poll Results: Which BOV are you running, or which do you like best?
Greddy type s
32
23.88%
HKS SSQV
33
24.63%
HKS Racing type 2
3.73%
Blitz dual stage
2.24%
TurboXS RFL
10
7.46%
GFB (with or without horn)
15
11.19%
Other
36
26.87%
Voters: 134. You may not vote on this poll
VTA BOV preference?
Old Jan 26, 2005 | 08:04 PM
  #31
glgz's Avatar
Originally Posted by bigric09
HKS SSQV is great, sounds great although i do like the greddy also, you can definitely tell the difference at the track... both are great... i just have the stalling issues...
another fix supposedly is the HKS EIDS does anyone know if that fixes it
I use the EIDS and it works great with my Greddy Type S VTA. Before I had the EIDS if I was revved up more than 1.5k and popped the clutch my car would stall or try to. Now it is gone. If anyone is considering it go for it. If I had to do it over the only thing I would do different is get the wire harness extender for the ecu has you do have to clip into the wires on the ecu. However, I have no problems from my wiring job.
Old Jan 26, 2005 | 08:16 PM
  #32
bdking57's Avatar
Iv got the new whistle attachment for my GFB... I vent about 20% of the air and its more then loud enough.
Old Jan 28, 2005 | 06:00 PM
  #33
hkfeet's Avatar
I got it too but I cant really tell a difference in the sound except it more quieter.
Old Jan 28, 2005 | 09:24 PM
  #34
Evo8kid's Avatar
I have the greddy type s...but im recirculating it....and its still really loud...almost as loud as the rfl....at the time i still had the stock air box though with the rfl...greddy is definityh a good blow off....no boost leak for me...
Old Jan 28, 2005 | 09:27 PM
  #35
evoviiiyou's Avatar
tial for me.
Old Jan 29, 2005 | 09:43 AM
  #36
bdking57's Avatar
****.. i just put on the whistle attachment. Cant here a damn thing, it sounds a little different but its not as loud completely defeating the point!
Old Jan 30, 2005 | 07:15 PM
  #37
Vroompsh's Avatar
Forge Rocks
Old Jan 30, 2005 | 07:19 PM
  #38
jbrown's Avatar
If you are truly going to VTA, then the SSQV is your only option to prevent stalling. Like it or not, it is the ONLY BOV that doesn't leak under vacuum (at idle). I learned this the hard way. I tried a Turbosmart (not the new evo-specific one), GFB, and Greddy before I kept the SSQV. My SSQV is crazy loud, sometimes even when I shift softly at 4000 rpm, and I'd rather it was quiet whn I wanted it to be.
Dual port is kind of a fake VTA, but great if you only want to hear it on hard shifts. The dual ports hit the recirc port a split second beofre the VTA port so that when they leak at idle, you don't stall. When you look closely, you'll see the VTA port is offset about 1/4" higher than the recirc port.
If you convert from MAF to MAP via an engine management system, it won't stall from VTA, even with leaking, but on the stock ecu, I promise it will with everything but an SSQV, I've been there.
Old Jan 30, 2005 | 07:24 PM
  #39
PoorBoys's Avatar
Forge Motorsports VTA is the only way to go. It is what EvoM put in their project evo. Here is the write up they did. https://www.evolutionm.net/features/.../projectevo/22
I have one too, and it is awesome.
Old Jan 30, 2005 | 07:35 PM
  #40
turboex's Avatar
So you can VTA the SSQV without any stalling, or idle issues. Is there anything negative about it? I had it on my sr20det and liked it, just want to make sure it will work with the evo. thanks
Old Jan 30, 2005 | 07:45 PM
  #41
evo_08's Avatar
greedy type r
Old Jan 30, 2005 | 10:42 PM
  #42
jbrown's Avatar
I didn't have any issues, just buy the evo-specific kit and install is easy, just make sure you have a really good pair of snap-ring pliers with 90-degree tips for that funky adapter gimmick.
The only other thing I recommend is going 2-3 turns stiffer than the unit comes out of the box so it's not so loose when it does blow off. Aside from that, the idle does dip down pretty low once in a while, but only for a split second. I think I have stalled maybe once in the past 4 months but to be honest, that may have been before the SSQV, I don't remember. Hope that helps.
Old Jan 30, 2005 | 10:49 PM
  #43
kmxxbadboy's Avatar
The Tial blow off valve is a great unit for those looking to vent to air. I have it on my car welded to the upper intake pipe.
Old Mar 7, 2005 | 02:56 PM
  #44
hawjdude's Avatar
Forge baby...!
Old Mar 7, 2005 | 03:10 PM
  #45
plokivos's Avatar
where's tial?
It's Tial or Forge. They're built to last and performance without too many peoplems.
Forge is plug in design, which i like for evo models. Welding mounts are pain in the a.
