P0401 EGR Flow Insufficient fix?
I searched and saw the fix was to check for a loose hose. is there anything else anyone can suggest? I have not really noticed a lose in power. I don't beat or go hard on it. Pretty much babied so I can't tell if there's a drop in power.
The only way for you to find out a loss in power is to gun it. Do you have a boost gauge?
Most likely you blew a hose off. A quick cheap fix is to get some zip ties and clamp down the two nipples on the egr valve behind/under the intake manifold. |
I had this problem after my transmission was re-built and put in. I had my hoses checked and my valve replaced. Only to find out that the plastic nipple had broken off in the hose! So when you are checking your hoses, make sure there isn't a shattered plastic in it, which was my case.
good luck |
when i gun it I don't really fell a huge difference in power. unfortunately, have yet to add in a boost gauge. i'll have to install it in the next few weeks.
is the egr hoses in back of the IM or the tB?
i had the same problem when i had my clutch done...its on the back of the intake manifold its a solenoid and the nipples probably cracked on it where the vacuum hoses are...i just bought a new egr solenoid and put it on and never had the code again
there is an "octopus" of Vacuum hoses which run all over behind the IM and connect to the two ports on the top of the TB, if you find you need anything from this setup let me know as I have all of it. typically the vacuum line comes off of either the EGR valve itself or the one way check valve in the large line is clogged or stuck closed. Let me know if there is anything I can do to help. I just eliminated my EGR system all together and modded the ROM so it doesn't throw an SES light.
Josh :usflag: |
cool i'll let you know jmelocik.
navy/airforce? i see your from newport news. i was navy living in VA beach for 5 years. |
Originally Posted by jmelocik
(Post 6018043)
Josh :usflag: |
EGR code doesnt give you a lose in any power. I fixed mine and the hose blew off again and again I don't even bother it with anymore
The problem ended up being the hose off the actual EGR valve. the only problem is how to clear the Check engine?
Originally Posted by NJ_evoIXgsr
(Post 6022618)
you need an obdii scanner to clear the code
reset the battery
Just take the negative cable off the battery for a few minutes. Bam code cleared.
