took it into the shop for p0401, and they concluded it was the EGR Solenoid...When I asked how they knew, their reasoning was that the lines were hooked up and intact. I'm going to see if I can investigate for myself before I allow them to pop a new $70 part in. Glad I found this thread
if the EGR port is clogged yet I disable the EGR, will it effect performance?
I just had my clutch and tranny replaced and got the EGR insufficient flow code. I'm gonna look at it tomm and check for loose lines. Hopefully that's all it is. I may just eliminate the EGR system. It won't affect performance anyway. My car is running perfectly fine with the SES light on.
Eliminate it in the ECU, remove the system when you have time (THats the last thing for me to do).
any easy way to reach the EGR valve?
Originally Posted by DesertEvolution
(Post 7941998)
this code is quite ANNOYING. i have to fix it again. i should have just tip tied it or like everyone else just did the egr elimination. i'll do it this summer when i actually have time. not working tremendous amount of overtime.
i can't find the hose for the vaccuum. anyone know where it should be coming from?
Had same code today. went to Autozone they gave me a reader, looked it up on evom= easy and fixed. Thanks
Same code. Thought for sure it was test pipe related.
Did the deep reach around on the throttle body & sure enough the hose dangle was found. Great thread:D |
Just got this code as well... Found this thread and fixed. The diagram is great since you're just feeling around back there and not able to see. great thread!
My CEL just came on as well, thought it was my test pipe as someone mentioned before. Come to find out I already put the non fouler on, reset the battery and the light went off. Looked back on the previous owners trip to firestone and sure enough it was the EGR valve code. ANNOYING! but simple and easy fix just ridiculous !
This just happened to me after a clutch install. Just found out that the nipples broke off the EGR solenoid. Damn $70 part!!
I have a same problem. Can block the EGR? Is it work?
