important: sick of acd/ayc discussion
Old Nov 12, 2002 | 09:40 AM
EVOL's Avatar
Request: Another post discussing AYC/ACD
Oh super, we've got one!
Old Nov 12, 2002 | 02:48 PM
hotstepper's Avatar
Thats just what im saying,,,,mitsu should put all those gadgets in the car to keep its reputation as that unique road rocket. I like ayc cause im researching it for my project as an intelligent system and it is a pretty neat and fascinating example. Ive never driven a subaru cause there werent many in Trinidad. Id like to know if the sti is fast but most ppl told me that the evo was faster.
BY THE WAY.......IF U WANNA TALK ABOUT MAINTENANCE,, THE BIG PROBLEM ISNT AYC, ,,,,,,, its the clutch grabbing all that torque.. IF mistsu doesnt fix this problem , u will almost certainly have to get a copper clutch system.,......You could launch the 6 at 6000 rpm and hardly smell the clutch....Do that with the 7!!!! no way!!!!!!...........
Old Nov 17, 2002 | 08:22 PM
Turbo-Ron's Avatar
Mr.AWD & Hotstepper....... Great info guys!!!!!!!!
Hey, I just made it back from the Miami Auto show:
Mitsubishi reps said that Evo 8 will be here in February, with 270 hp, and no AYC. They could not comment about ACD for some reason. But said that base price around 28G !!!!!!!!
I've noticed in the past that manufacturers often hold back some of the "goodies" on early models, so that when demand and sales start dropping off, they give you more features to bring sales back up.
I won't be surprised if does it with the Evo
Subaru is doing it with the STi.
Old Nov 19, 2002 | 10:40 PM
NismoSkylineGTR's Avatar
In Timeout
ppl really need to watch their language here
host try to put a censor in her so when ppl type the F word or whatever bad word it wont be post cuz i'm sure not everyone here are over the age 18 we dont wanna ruine a young racer's mind with faul language here do we?
Old Nov 19, 2002 | 10:41 PM
In Timeout
thats' cuz wrx is not as hot as it first came out
so sti is coming
and l've said it b4 STI is a subcompany that' build cars for sub so the 3rd party company will surly bring everything cuz they aint gonna mess their image up
Old Nov 20, 2002 | 07:57 AM
BurnOutz's Avatar
Yeah people, stop @#*$&@ cursing here! There could be some @#*(*$$&#*@(* kids in here that shouldn't be hearing this @(*#! So shut your #*$(*&@ mouths. Thank you!
j/p
Old Nov 20, 2002 | 10:48 AM
MrAWD's Avatar
Originally posted by Claudius
Back on the ACD / AYC topic. You guys seem to glorify these systems, when in fact they are more of a safety feature than a performance nhancement...
Surprising statement from you Claud, to say at least. Why in the world those WRC guys have all three diffs electronically controlled then? Safety? I don't think so.
Of course, the systems that we see in the EVO 7 is nowhere close to the one in the WRC Lancer, but it is still better than not have it at all! And the good thing is that electronics (at least the modern one) can be reprogrammed and it can work much better and closer for the particular needs of a driver. If you have the best mechanical LSD in there, you need to take it out in order to modify it. And, even if that wouldn't be the case, you are limited to the one setup at the time and no mater how hard you try, that is it!
Hmmmm...
Mr. AWD
Old Nov 20, 2002 | 11:45 AM
MrAWD's Avatar
WRC cars electronic LSDs are nothing like an AYC system. The diffs are set the way the driver needs them for the rally, possibly even adjustable from inside the cockpit, not sure.
That could be true, but I don't think they (WRC drivers) do that. They seem to be busy enough just driving that thing, and adjusting the diffs would be a little over board!
They are of course nothing like the stock ACD/AYC combo, but once you have it, at least there is an option to adjust them the way you want them. If new EVO doesn't get any of those gadgets, my Talon might get part of the active setup over the next few winters. We will see!
Also posted by Claudius
AYC is like ESP on an Audi, with the exception that it doesnt cut engine power off, but keeps the rear from sliding. No sideways action with AYC. Safer, but not more fun. Why do you think I took mine out?
Had a seizure or something
I do believe that the factory setup is meant to be for the safer driving and tarmac option might be a bit too tight for the more serious racer.
I will spend one more reason for sure with the mechanical diffs in my car and try to improve the settings on my shocks. They do have enough adjustment and more tuning might help as well. The main problem that I am facing here is that the current setup is inheritably pushy and it is not easy to find the best possible balance, since things change a lot and I can't adjust those diffs for every single race. Adjusting the rebound setting is a challenge enough when switching from the asphalt to the concrete surface. That is why I am planning on using electronically controlled setup, which should help!
And posted by Claudius
As for the ACD, that could be an improvement, but in fact has been transformed into a safety feature: You can change it from neutral with a slight understeer bias (TARMAC) to more understeer (GRAVEL) and SUBARU ie a lot of understeer (SNOW). That's good for snow or sand and gravel not to spin / crash loosing the back, but not for the track, where you may like a 40 / 60 setup for powerdrifting
I am not sure that you can separate those two system and put one in the front of the other. They are doing similar things but each one on its own is not good enough to catch all of the possibilities! With two of them together, they can push one of them further and keep it under the control with the other one. That is what makes the combination of those two a great thing. That is why I think drivetrain feel between the EVO 6 and EVO 7 has it s roots!
Mr. AWD
Old Nov 20, 2002 | 03:40 PM
MrAWD's Avatar
As I said, there's an ECU for the ACD, and that's it. Cant adjust the AYC.
Both of those systems are controlled from the same controller. Co by having the control of that one, you are in charge of both!
Which two systems? The ACD and the AYC?
Yup! By separate, I was referring to the behavior of the EVO 7 and how things would be if you would have only one. I believe that, by disabling the ACD and replacing it with mechanical LSD, EVO 7 would behave pretty much as EVO 6.
Mr. AWD
Old Nov 22, 2002 | 07:23 PM
MitsuEVOVIII's Avatar
Everyone just remember this the good-ole Government has alot to do with the specs on the car just think they had to redesign the front bumper to meet our stupid 5mph crash rating just think what they did to all the extra goodies to the car the government makes me sick
Old Nov 24, 2002 | 12:00 PM
EvoWannabe's Avatar
Question hmmmm
On the other hand, thanks to our government, the car will be safer, and if you hit someone at 5mph you won't have to spend a couple grand to fix your intercooler. just my $.02
