Manual or electronic Boost controller???
Old Oct 2, 2004 | 10:52 AM
AUSS1E's Avatar
which is better value for money. the Manual or electronic? I may in the future upgrade to EMS that has boost control, So I am thinking that the Manual may be the way to go. But even if I didnt upgrade to EMS later is the Manual BC still gonna cut it in the long run???
Old Oct 2, 2004 | 11:02 AM
bluebanana23's Avatar
I would say manual because you would only need to set it when you first install it then probably never again. Electronic if you plan to change it a lot in the convience in your car but like you said EMS is the way to go and I highly discourage the use of a greddy b spec...
Old Oct 2, 2004 | 12:13 PM
AUSS1E's Avatar
Yeah im thinking manual.....spend the other money on a downpipe
Old Oct 2, 2004 | 12:15 PM
Rez90's Avatar
for the money there is no question...manual
Old Oct 2, 2004 | 12:28 PM
EVO316's Avatar
it all depends on what you want, if you want to save money go with a manual. if you don't mind spending money go with an EBC (HKS is a good and easy one to use). some like one over the other. I like ebc cause i don't like to open my hood to change my boost every time.
Old Oct 2, 2004 | 12:36 PM
ctevo's Avatar
go wit the manual. I had a GReddy EBC and could never get it to tune just the way I wanted, switched to a hallman MBC and am holding 20psi all the way to redline.
GReddy Profec B Spec II for sale asking 300
Old Oct 2, 2004 | 01:17 PM
evo81's Avatar
Hallman rx pro mbc all the way.
Old Oct 2, 2004 | 01:18 PM
umiami80's Avatar
Manual, if the EBC malfunctions, and they DO as the are electrical Vs. Mechanical, you get open boost ,meaning no boosyt control. MBC by Hallman, used on 9 second DSM's. Bushur uses one on his race car, its king
Old Oct 2, 2004 | 01:31 PM
AUSS1E's Avatar
who sells the hallman...cant find it on any of my sites
Old Oct 2, 2004 | 01:32 PM
Thoe99's Avatar
manual
Old Oct 2, 2004 | 01:41 PM
AUSS1E's Avatar
just found em at machevo.com
Old Oct 2, 2004 | 04:27 PM
rburris28's Avatar
I agree with choosing a manual, and agree that they are less likely to fail than an electronic control; but, if the hose to the MBC comes off, you also have no boost control.
So put clamps on those hoses!
Side note: I had thought of disconnecting the boost control and just having the wastegate open at its normal pressure (14 psi or so) when my kids reached driving age. I tried my car without the boost control and saw a peak of 14 and 13 to redline. '
It was STILL too fast for a novice driver.
Old Oct 3, 2004 | 03:20 PM
gsujeff55's Avatar
yeah, but do you have to put the heavier spring in it? i mean, the stock boost on the wastegate of that turbo is like 14psi, RIGHT? so, if you wanna run 20-21psi all day....you have to use the heavier spring?
Old Oct 3, 2004 | 04:16 PM
djmikeymike's Avatar
i'm looking to get a MBC and i was going to get the greddy b spec but you guys don't seam to like it. could someone tell me why? or is there a better Ebc? i don't want to go over board with it i just want to hold 19psi to red line and maybe have a lower setting for winter and normal driving. Also i want to get the buschur raceing 3" turbo back but i don't have the money right now. could i start with the MBC with out herting anything? or should i wait and get the turbo back first
thanks for the help
Old Oct 3, 2004 | 04:19 PM
bump
