Fluttering sound on decel
I have a 366hp Turbo Trix tuned EVO with AEM EMS/TIAL VTA BOV and all the bolt ons. I bought it used recently and overall its great. I believe its running properly, I'm just trying to understand it. When the turbo builds any amount of boost and I let off the throttle at all makes a fluttering air sound like a rattlesnake. When I romp it good and let it off I hear the BOV blow. From thread searching I assumed it was coming from the BOV and was normal or maybe I need a lighter spring.
I opened the hood to see if the flutter was coming from the BOV and it actually was coming from the Intake Pipe/filter. The BOV was closed tight when the flutter sound was happening. Again, when I would give it some gas I could clearly hear the flutter from the intake and eventually a nice even blowoff from the BOV. I trust the TT tune and the car is running great, but if someone could explain what's going on I'll be a little less dumb. My standard "this is my first turbo import after a long line of cuby V8's" disclaimer applies. Thanks!
Yup, that rattle snake flutter is compressor surge. I just replaced my turbo due to a destroyed thrust bearing. I was running way to much boost for the stock turbo, but I also think the compressor surge had a lot to do with destroying the thrust bearing. Now with the new turbo I want to protect my investment, so I researched the possiblility of getting a weaker spring. After swapping to the lightest optional spring I now have ZERO compressor surge
Later,
Keith
Later,
Keith
I too am milking my stock turbo and have done about all I can mod wise short of higher octane and water/alc injection. How much boost were you running when you wasted it? Did it go instantly, or degrade? What were the symptoms? What did you replace it with?
The stock compressor can not keep up with the 272 HKS cams resulting in more boost tapper than I would have with the stock cams or 264's, but at this time I can't really aford a significant turbo upgrade so I went with the direct bolt on. With the demands of the 272 cams, running 23 psi to redline is over spinning the living $hit out of the stock turbo. Combine that way out of spec shaft speed with compressor surge when letting off the throttle and you end up with a damaged thrust bearing.
I just noticed your screen name, you a squid? I spent 10 years in as a Nuke on Subs
Keith
PS: Reason I am switching to GM boost solenoid is so I can run 21 psi at redline without having to spike up to 24 in the low RPM range to get there.
I'm running 272's at about 24psi peak on pump gas. So with the solenoid, the ems is setting your boost? What kind of hp are you making on pump gas? Sounds like our mods are similar.
Yep, squid here. Helo pilot 5 yrs in.
Later,
Keith
J Yim
Jan 25, 2016 01:00 PM
caduprado
Jul 12, 2015 04:15 PM
shadow1
186
Sep 18, 2011 10:14 AM
