any things u can do to the car to make it smooth?
Old Oct 19, 2004 | 05:11 PM
TwoMix9900's Avatar
we all know that evos (03 at least) is known to be...rough...(for instance, boosting up to 3k+ rpm in first gear and jus letting go of accelerator...i honestly dont know if its the same for all cars since im the only one among my frineds who has a manual car...)...so is there anything u can install for the car to make it more...civilized?
Old Oct 19, 2004 | 05:12 PM
tokeone's Avatar
a grounding kit may smooth it out a little
Old Oct 19, 2004 | 05:13 PM
Agent-Smith's Avatar
Shifter bushings, synchromesh tranny fluid.
Other than that - no. Its the awd system transfering torque and maintaining traction cause the "roughness" add to that how stiff the suspension is and there ya go.
Old Oct 19, 2004 | 05:20 PM
w2pac12345's Avatar
yeah... buy a BMW. It is an expensive mod but it will give you a nice smooth ride you are looking for. jk.....
Not much you can, except get used to it
Old Oct 19, 2004 | 05:37 PM
Jadiem's Avatar
i know what ya mean.. i have one of the last 03s and i do notice some trouble in breathing when i'm crusing...
i'd do the grounding kit, tranny fluid, 2 pc metal, and 5-8 pc poly.. not saying it'll go away, but thats the ONLY things you can do short of going FWD...
Old Oct 19, 2004 | 05:46 PM
Az3ar's Avatar
different tires, different oil in tranny (penzoil), ECU mode to smooth out the power band and last ear plugs.
Old Oct 19, 2004 | 08:00 PM
Jakeg97's Avatar
get bilstein shocks , like the mr has. that should smooth out your ride!
Old Oct 19, 2004 | 08:41 PM
bolsen's Avatar
syncromesh
and also learning how to drive a turbo car is key (no I'm not making that up)
Old Oct 19, 2004 | 08:50 PM
ARVSHOP's Avatar
Reflash your ECU so you can widen up your powerband, get Tein (or something similar) coilovers and set it to softest or near there and I promise you, your car will be much smoother....oh and set you tire pressure to 32 psi and you car will run much smoother.....thats what I did...I had the same problem...
Old Oct 19, 2004 | 09:17 PM
invazn's Avatar
get an intake..that should smooth it out.
