should I keep stock MR bov
Old Oct 20, 2004 | 07:36 PM
herbal77's Avatar
I beleive the bov on my new mr is plastic, should I keep it stock or replace,with what though. I would like to here the "psshh" between gears.
Old Oct 20, 2004 | 07:38 PM
MENTY's Avatar
4 WHAT REASON?????
Old Oct 20, 2004 | 07:42 PM
AznFlip's Avatar
Originally Posted by MENTY
4 WHAT REASON?????
he said he wants to hear the "psshh" sound
Erik@MIL.SPEC's Avatar
VTA blow off valves tend to screw up Evos. Unless you're running speed density, I would stick to stock, or get either the MR jdm valve or a 1G DSM valve.
Old Oct 20, 2004 | 07:43 PM
herbal77's Avatar
I heard the metal ones were better, and I like the pssshh sound when shifting.
but if the mr bov is good , i'll keep performance.
Old Oct 20, 2004 | 07:45 PM
MYEVOVIII's Avatar
So the new US MR's are coming over with the same as stock VIII's plastic BOV. Not the metal one that is selling so well on this site. I thought the MR's came with the same style????
Old Oct 20, 2004 | 07:46 PM
chinto's Avatar
a MR should have a metal bov, the pssshhh sound if u want to hear it more get a differnt intake. or get a k&n drop in filter
trinydex's Avatar
you don't have to get vta in order to hear the purge sound. and you can vta on the stock valve too. wow.... how do you guys not know this? get an open element intake, basically... replace the stock intake box... you'll get all the pshh and sssss (turbo spool) you can handle (i'm running hks rs, sounds great!) if you want to run the stock mr valve vta make sure everything is nice and tight, if you lose air it's all goin' to the atmosphere after already being metered and you'll get some ****ed up bucking.
GPTourer's Avatar
An open filter intake will amp up the psssh sound.
Beyond that, i have heard Evos to be real finicky when it comes to BOV's. Some people use 1G DSM CBV's to great sucess. Others do well the GReddy Type S. Don't VTA.
Old Oct 20, 2004 | 07:47 PM
marksae's Avatar
herbal77, if you want the sound w/o sacrificing too much driveability, get the WORKS/GFB dual vent valve.
http://www.worksevo.com/store/produc...products_id=34
Old Oct 20, 2004 | 10:34 PM
redevo8driver's Avatar
the mr bov holds boost just fine..so if you want the pshh sound just get the adapter and high flow filter kit from buschur or you can even get on off ebay for like 16 bucks..then just replace the filter with a k+n later if you want..if you got another bov without getting an open intake you wouldnt hear much sound..but even the stock bov makes plenty of sound by getting rid of the stock airbox..
Old Oct 21, 2004 | 07:29 AM
DynoFlash's Avatar
Lovely eh?
Old Oct 21, 2004 | 07:30 AM
VTECH8TR's Avatar
Mitsubishi blows .
Old Oct 21, 2004 | 07:34 AM
Event-Horizon's Avatar
Yeah, only the JDM version comes with the "MR" BOV. If I were you and was going to buy a new BOV, it would be the MR BOV which I have in my car. With a K&N drop in filter you can hear the "psshhh" sound a little bit. And if you're going to get a BOV make sure its for a reason other than the noise... cause its not ment to get you laid or anything silly like that.
Old Oct 21, 2004 | 07:36 AM
DynoFlash's Avatar
I concur - I really highly recomend the metal MR valve
