type of gauges to use..
Old Oct 31, 2004 | 01:53 PM
J8dailo's Avatar
im a newbie when it come to gauges..i been wanting to add 3 gauges to my evo viii..im going to mount it to the A-pillar... just wondering...what gauges is everyone else using? for me... boost, oil pressure, oil temp... i don't know if thats a good combination...what you use?
Old Oct 31, 2004 | 02:01 PM
IamHung's Avatar
If you were to only do 3 gauges, I'd swap the oil pressure for an EGT gauge.
Old Oct 31, 2004 | 02:04 PM
en1gma19's Avatar
no way. oil pressure is the first guage you should buy, then boost, then egt
Old Oct 31, 2004 | 02:56 PM
boostindsm's Avatar
personally i'd go with boost, egt, and oil
Old Oct 31, 2004 | 06:41 PM
lil'evil_evo's Avatar
oil pressure, egt and boost. I would buy Defi gauges.
Old Oct 31, 2004 | 09:25 PM
DjRiice's Avatar
isn't there a poll of this..."most important gauges" something like that? any ways i think it was unanimous that it was boost…oil…and egt…..don’t quote me though just search.
Old Nov 1, 2004 | 05:44 AM
Cirrusly Evolvd's Avatar
With the low tolerance of knock on our engines Boost is most definately the 1st gauge to buy. Even if you aren't running higher than stock boost pressure its a peace of mind item. Oil pressure comes in next. Oil temp isn't as important unless you are always running your car hard. If you have Oil Press. you will notice a change if your temp goes up too high. And finally would be EGT, another indication that will help you determine if you are running a bad A/F mixture.
If you can afford them, Defi is the shizzle.
sagravtj
Feb 10, 2017 08:55 AM
EvoX267
Sep 18, 2015 11:21 AM
rooney08
Apr 23, 2011 04:48 PM
IDRINKV8
Apr 4, 2006 07:17 AM
JeffWels
Aug 20, 2004 08:30 AM
