Shifting Techniques
Old Nov 1, 2004 | 08:58 AM
EvoJeff's Avatar
Shifting Techniques
Can someone explain the mechanics, benefits, and detriments to "lift shifting", "power shifting" and "speed shifting". If you can think of other techniques I haven't mentioned, which I'm sure their are plenty, please add them.
Old Nov 1, 2004 | 10:01 AM
EvoRs's Avatar
Power shifting is where you accecelerate hard in first or 2nd, and right in the middle of the powerband, while keeping the pedal to the floored to the ground shift into the next gear, this causes your rpms to soar, and hits the next gear right in its powerband...basically making the tires light up and launches you like crazy
Old Nov 1, 2004 | 10:02 AM
EvoRs's Avatar
Btw.. powershifting is hard on your clutch and gears, and if you dont shift fast enough ull hit the revlimiter and start bouncing off of it which isnt good as well.. But man does it launch you
Old Nov 1, 2004 | 10:13 AM
EvoJeff's Avatar
Have you ever heard of lift shifting?
Old Nov 1, 2004 | 10:26 AM
oak2207's Avatar
I would guess that "lift shifting" is how we all shift on a regular basis, lifting off the throttle between shifts. Power shifting and speed shifting I thought were pretty much the same thing...someone correct me if I'm wrong.
Old Nov 1, 2004 | 10:45 AM
twinevo's Avatar
i thought speed shifting is just normal shifting at a speedier(duh) rate done in order to keep the rpms from dropping down to much. why would you want to keep your foot on the throttle when engaging the clutch unless you were launching from a stop.
Old Nov 1, 2004 | 11:33 AM
pwrd_by_diznutz's Avatar
when i shift quick i take my foot off the pedal half way when i switch gears it pulls you back every shift is this bad in any way?
Old Nov 1, 2004 | 01:15 PM
blackevoVII's Avatar
over time...yes...id think.
Old Nov 1, 2004 | 03:42 PM
plokivos's Avatar
You should check out the driving techniques under competition thread. They cover this pretty well.
awdboosted
Feb 16, 2012 09:54 AM
03chi-town0Z
Nov 26, 2010 11:24 AM
KazzEvo8
Driving Techniques
18
Apr 16, 2009 11:43 AM
rghli
Driving Techniques
27
Mar 9, 2006 04:32 PM
figit
12
Dec 4, 2005 08:32 AM
