Evolution MR dyno results
Old Nov 17, 2004 | 05:45 AM
kmxxbadboy's Avatar
On 11/16/2004 I had my Evolution MR dyno tested at Pruven Performance in Milford, CT. The first run was a baseline reading. The second run was done after the installation of a Hallman manual boost controller. Please keep in mind that there is no ECU tuning done on this vehicle. The car was running 94 Sunoco Ultra. The results are below:
Please see my signature to find the link that will take you to the list of modifications that I have done to the vehicle so far.
As tuning support is very limited for the 2005 model line, I wanted to ask what route I should go for simple fuel adjustments to smooth out my curves and squeeze out a bit more horsepower from the mix. I am considering using an APEX'i S-AFC2 as a temporary fix. Any suggestions would be greatly appreciated.
-Mike
EVO-NY #666
Old Nov 17, 2004 | 05:54 AM
cutlass73's Avatar
I can't imagine that the ECU is any different than 04 or 05 unless I haven't been keeping up on current events? In that case use a UTEC, XEDE, or get it Dynoflashed, etc to get it tuned. An SAFC will be less expensive but that's just fuel.
Old Nov 17, 2004 | 06:17 AM
modvp's Avatar
What PSI did you have your boost (Hallman manual boost controller) set at?
Old Nov 17, 2004 | 06:31 AM
kmxxbadboy's Avatar
modvp - I believe they set it to a conservative 19 pounds.
cutlass73 - I think that with the addition of the ACD, there would be some minor changes to the ECU for the 2005 model line. Small changes, but still changes that any aftermarket tuning unit/flash may not take too kindly to.
Old Nov 17, 2004 | 06:46 AM
wtz's Avatar
wtz
The ACD is a seperate system controlled by its own ECU.
Old Nov 17, 2004 | 06:54 AM
twan's Avatar
Cant wait to see a standalone or a flash on that baby!
Old Nov 17, 2004 | 06:59 AM
GOKOU's Avatar
i'm curious as to how the basline is so high 260? but would even more curious to see what a flash would do
Old Nov 17, 2004 | 07:03 AM
Greg K's Avatar
gotta love the boost spike at about 4k. My stock MR does that too and it's a rush.
Old Nov 17, 2004 | 08:33 AM
Erik@MIL.SPEC's Avatar
With a piggyback, you could keep that boost spike, right?
Old Nov 17, 2004 | 08:37 AM
b18flip's Avatar
wow that's a nice baseline run...and nice results w/ the mods.
Old Nov 17, 2004 | 09:01 AM
DynoFlash's Avatar
-Mike
EVO-NY #666
Within a few days we will have the Dyno Flash available for the '05 Evos - since you are in the area I would offer you special pricing as a beta tester on the '05 - check the forums as I will make an announcement on it when its out - (literaly any day now)
Old Nov 17, 2004 | 09:20 AM
mybada's Avatar
looks like you lost some torque from the mod... 289.5 to 265??
but 260 hp baseline is impressive... something you can never do with gsr!!
Gosh MR is so nice!!
Old Nov 17, 2004 | 09:25 AM
twan's Avatar
Awesome news for us 05'ers !!!!!!!!
Old Nov 17, 2004 | 09:31 AM
Centrylancer's Avatar
wow, very impressive
Old Nov 17, 2004 | 09:32 AM
Willie Dynamite's Avatar
His car is not stock, click on his link in his sig. For baseline he means before the mbc was installed.
