Humming clutch??
Old Nov 20, 2004 | 12:47 PM
PersianEVO's Avatar
Humming clutch??
I have a strange sound when I am slowly releasing the clutch especially at high speeds 50+. It is a mid tone humming sound. The performance of the clutch doesn't seem to be affected and everything seems to shift ok but it is a rather loud humming sound that always happens when I have to slowly release the clutch (ie engine braking) What could this be??
Old Nov 20, 2004 | 01:08 PM
jcnel_evo8's Avatar
I have this same problem ... I mostly notice mine letting out the clutch with the rev. slightly lower than the gear and speed wants the motor at in 2nd gear. I think its a throw out bearing. I've adjusted my driving to miniminze this. I'd be curious to know what it 'really' is and if its a problem. Mine started about 2k miles, and I've got 10k on the EVO now.
jcnel.
Old Nov 20, 2004 | 02:43 PM
Derek888's Avatar
I have that same noise but I think its the transmission making that noise when you downshift or release the clutch at a certain speed?
Old Nov 20, 2004 | 04:39 PM
PersianEVO's Avatar
I'm just worried it is a sign that something bad is happening. It'e really weird because it only happens when I release the clutch slowly. It's like a steady hum. As soon as I'm done shifting though it just sounds normal.
Old Nov 20, 2004 | 04:42 PM
BlackEvoEight's Avatar
I had that too it when away when I switched clutches...
Old Nov 20, 2004 | 04:50 PM
simevo's Avatar
I had it for awhile but it's not doing it as much. I hear it when releasing the clutch slowly like into second gear. I have the stock clutch and 24K miles.\
I say it's pretty normal for Evo's.
Old Nov 20, 2004 | 11:27 PM
plokivos's Avatar
it's fairely normal. MOst of the time, it's your intake making this noise. But it could be the sign that your clutch needs replacing.
Evo'lusive
May 11, 2016 03:59 AM
honki24
Apr 16, 2015 09:06 PM
Jaxson75
Lancer Troubleshooting
Apr 11, 2015 06:59 AM
EvoTurboTurk
Mar 1, 2013 01:01 AM
EVL!EVO
May 11, 2012 10:15 AM
