RS=barely lighter, MR=heavier
http://www.roadraceengineering.com/e...evoweights.htm
The RS is like 18lbs lighter than the stock GSR (when you subtract the weight of the sunroof from the GSR)
Road Race weight the HID's in at around 17-18 lbs. Seems like thats all the weight you're really saving, plus whatever extra gas was in that car.
The MR weights MORE than the GSR, even when you account for the 60lbs of junk in the trunk.
Seems like the weight reduction was hyped up a bit by
Not really.
It's about 88 lbs, between the RS and the MR. The major difference between the RS-MR and the GSR is the roof. giving it a lower center of gravity. All the other stuff is minor. The RS is sold to customize. Most people will replace the stock radio. And ABS doesn't help when trying to drift the car. You shouldn't be buying the car just beacuse of the weight. Its the overall picture.
Originally Posted by Clue?sion
Not really.
2) most people that track the car don't replace the stock radio really.
3) i dont think anyone bought the RS to drift. At least i should hope not. But for the track, the ABS actually helps. Ask some people with the RS how they like not having ABS at the track.
4) i think, the overall picture is that the MR seems like a pretty good value still b/c you get the 6-speed, the forged wheels, and the VG, while still retaining the HIDs
Originally Posted by EVOLust
Just out of curiosity...Doesn't the RS actually come stock with AC? Every one that I have see has it.
Originally Posted by alex_alex
1) the difference is 88lbs when comparing the RS without a sunroof to the gsr WITH a sunroof. The sunroof weighs 35 lbs. the CORRECT comparison is to a gsr without a sunroof, which is only 53 lbs heavier, 17 of those pounds are from the HID's. So, all the other stuff really only takes of 36lbs.
As i understand it, i think its an option added on, but like 90% of them have it
It was only optional on 04 models
It also does not have any sound deadening, trunk lining, power mirrors, windows.,
I believe it has an aluminum roof panel. Mitsu says it works out to be 150 lbs difference.
Originally Posted by Wicked
the rs doesn't even come with a radio i thought, and even though the hid's weigh 17lbs. how much does the non-hid's weigh, probably a good 8-10 or more?
