Reverse lamp not working
Old Dec 26, 2004 | 11:06 AM
RalliArtEvoVIII's Avatar
My rev lamps not working. The plug is plugged into the tranny but still doesn't light up. What could it be. Any other plugs I failed to check. Everything works except that.
Old Dec 26, 2004 | 11:08 AM
EvoEightMR's Avatar
maybe it's loose...
Old Dec 26, 2004 | 01:18 PM
no its not. I took it out and put it back in ATLEAST 10x in the past month. Nothing. Wont light up. I even stuck a Q tip in the plug to clean it, still nothing.
Old Dec 26, 2004 | 01:20 PM
solarxclipse's Avatar
Maybe the bulb is busted.
Old Dec 26, 2004 | 05:07 PM
No bulbs are good. Somethin wrong wit connection
Old Dec 26, 2004 | 05:27 PM
MalibuJack's Avatar
How about the fuse?
Old Dec 26, 2004 | 05:28 PM
dizzigital's Avatar
yes, fuse.
Old Dec 26, 2004 | 05:43 PM
mrbkkt1's Avatar
you are going to have to use a multimeter, or light probe tester to check you light @ diff points along the way. i would start w/ bulbs, then go to plug, then go to taillight connecter etc. assuming that both lights are not working, then it probably be a problem before the split for the 2 lights. i.e. fuse, tranny harness etc. sometimes the easiest thing will be the prob. so make sure you check fuses.
Old Dec 26, 2004 | 05:58 PM
Quickshift's Avatar
Ya using a DVOM will be your best bet. I would do a Ohm test on the switch to see if the circuit is stuck on open when the tranny is placed in reverse. If the switch is good you would see 0.1 in resistence from the terminals on the switch. If bad it would be some astronomical number.
Old Dec 27, 2004 | 01:19 AM
where could i get access to these testers? BTW, which fuse is it in the fusebox? Cant figure it out alone wit the lil symbols
Old Feb 26, 2006 | 09:52 PM
sonicnofadz's Avatar
I have the exact same problem. Did you find a solution? Which fuse is for the reverse lights?
Old Feb 26, 2006 | 10:58 PM
PeteyTurbo's Avatar
I had the same problem in my galant and changing the sensor that seemed ok for a new one resolved the problem.Best to troubleshoot with a meter though first.
Old Aug 5, 2007 | 09:55 PM
sorgar001's Avatar
i have the same problems, can anyone help?
TTone769
Nov 2, 2016 11:27 AM
anjapower
Mar 20, 2010 12:35 PM
Hot Wheelz
Dec 14, 2006 05:31 PM
westchester evo
Feb 17, 2005 11:54 AM
ZapcoLancer
Lancer Troubleshooting
69
Sep 27, 2003 05:10 PM
