o2 simulator needed
Old Jan 12, 2005 | 10:07 AM
Jersey PI's Avatar
o2 simulator needed
Do you think this will work?
www.o2sensorsimulator.com
any help will be appreciated.........thx
Old Jan 12, 2005 | 10:19 AM
thestaton's Avatar
I went with the one from Perrin from lancershop.com, it was expensive but it worked I've also heard that David Buschur sells them for like 45 bux....
Old Jan 12, 2005 | 10:31 AM
stvbreal's Avatar
Someone needs to come up with a design that plugs directly into the plug the stock O2 sensor gets plugged into. No splicing of wires. Just unplug and remove your O2 sensor, plug the O2 sim in, cap the hole in the exhaust and that's it.
Old Jan 12, 2005 | 10:59 AM
1.8t's Avatar
Why not just build the mechanical 02 sensor like the subbie boys? Use the two 02 foulers from autozone and drill one out to 1/2".
Old Jan 12, 2005 | 11:00 AM
ThEHiTMaN's Avatar
I used the mechanical one. Over 8,000 miles on it no CEL AT ALL! It's very easy, and VERY cheap.
Old Jan 12, 2005 | 11:01 AM
stvbreal's Avatar
Interesting. How do you make one?
Old Jan 12, 2005 | 11:02 AM
UFO's Avatar
UFO
Because on some exhausts, like mine (Perrin), it puts the O2 sensor in such a position that it hits the underside of the car and gives a nice rattle sound as you drive down the road.
Old Jan 12, 2005 | 11:03 AM
stvbreal's Avatar
Good point. Hell, I haven't had one that lasted long enough. They work for a few weeks then dud. I'd like to find one that is dependable.
Old Jan 12, 2005 | 02:09 PM
JT_EVO8's Avatar
I have the one from o2simulator.com and it works great. Wired it into my Fields harness with my SAFCII. No trouble at all.
Old Jan 12, 2005 | 02:15 PM
sleet's Avatar
I got an o2 simulator with my buschur exhaust and it worked fine, its the same one as listed above too.
Old Jan 12, 2005 | 02:17 PM
plokivos's Avatar
I got the dealer flash. No cel light for lack of cat on cat delete.
hopefully i coud pass emissions.
Old Jan 12, 2005 | 03:47 PM
Jersey PI's Avatar
thx for all the info........the sim for this site is only $23 as compared to $50 & $75
I think I will go this route. spend the other money on my cam(s) fund.......lol
Old Jan 12, 2005 | 06:09 PM
ThEHiTMaN's Avatar
There is a post here in the forum. Basically all you do is buy Anti foul plugs at your local auto store and drill out the center of 1 of them to 1" I think. You usually get 2 in a pack so you screw 1 onto the DP bung with the little hole in it and the one that you drilled out screws onto the O2 sensor and then onto the one that is already on the O2 bung. Not sure what size you would have to find that in the post. It works great for me. It did rattle 1 time but that was because the O2 sensor came lose because I did not want to tighten it to much in fear I would crack the anti foul plug that I drilled out. 8,000 miles and running strong. My car has never seen a CEL yet.
Old Jan 12, 2005 | 08:38 PM
RogueSTi's Avatar
Yep...I have this problem with the Greddy exhaust. I will be switching to an electronic O2 simulator soon.
Old Jan 12, 2005 | 09:44 PM
Jakeg97's Avatar
search
Stealthgyro3
Jan 10, 2012 02:29 PM
rish197
12
Feb 1, 2007 05:16 AM
mcbrown35
Lancer Aftermarket Forced Induction Tech
Feb 24, 2005 07:20 AM
93esp
Dec 26, 2004 06:38 AM
dazz
Jan 9, 2003 07:42 PM
