Question about Greddy Type-S BOV Single Spring Mod.
Old Jan 16, 2005 | 02:46 AM
Hong Kong Evo's Avatar
Question Question about Greddy Type-S BOV Single Spring Mod.
I currently have the Type-S installed on my evo and I was planning on getting the apexi intake soon... I was just wondering if it would be reccommended to put the other spring back in the BOV so that it won't flutter....
If anyone has the same set up, feed back would be appreciated.
Also, how is the Injen intake + upper IC compared to the Apexi Intake + heat shielf? Is the injen take maintenance free? Which is a better deal?
thanks
Old Jan 16, 2005 | 02:58 AM
sylvester31's Avatar
with one spring, the bov can not hold over 16 psi ( this is from my own experience) it would leak. with both springs it can hold 21 psi. it will always flatter, no matter what you do.the intake will make it louder, that's about it other than that you can run it with the stock air box or any intake as long as it is recirculated you'll be fine.
i have the injen intake and i love it, you wont gain a lot of power from it may be 10 or 15 whp, but it looks nice and it comes with the upper intercooler pipe.
Old Jan 16, 2005 | 05:29 AM
EVOTEXAS's Avatar
I have done the single spring mod and it holds 22 psi or 25 psi just fine and dandy.
Old Jan 16, 2005 | 07:47 AM
nhsean69's Avatar
JUst make sure you put the right spring back in and it will hold PSI fine. I had a Pruven BOV (same as Greddy with pruven name ontop) with both springs in and the idle sucked and car would stall sometimes. Switched to the Greddy Type-S with single spring but i had put the small spring back in not thinking, and it definatly leaked!! Figured out my problem and put the bigger spring in instead and the car pulls the same as it did with the Pruven which was giving me all those problems.
05evoGSR
10
Aug 14, 2006 11:40 AM
ZoSilverEvo
17
Jan 25, 2006 02:57 PM
2006evo
10
Jul 13, 2005 08:53 AM
04Evo8RS
May 11, 2005 04:42 PM
bigjhoney
Jan 29, 2005 03:00 PM
