Whats My Next Mod?
Old Jan 17, 2005 | 06:49 PM
jrhecker's Avatar
Whats My Next Mod?
allright....i realize there will be a ton of different opinions on this matter so lets try to keep it civil. i want to know where to go from here with my car, basically here's what i have:
*Turbo Back Exhaust
*Intake
*Greddy Emanage
*Manual Boost Controller
*Upgraded Intercooler and Upper and Lower Pipes
*Wahlbro Fuel Pump
so anyway i am looking to get into the mid 11s by summers end, i am going with cams next (that much i know) hks 272s, what i don't know is whats next from there? should i get cam gears, do i need injectors, whats next?!?!? any advice on this would be appreciated
Old Jan 17, 2005 | 06:50 PM
evo_il8's Avatar
turbo back
Old Jan 17, 2005 | 07:01 PM
jrhecker's Avatar
that is the first thing listed, are you joking or something?
Old Jan 17, 2005 | 07:06 PM
SilverCOEvo's Avatar
I'd have to say that if you're dragging a lot, and looking into the mid 11's, I'd think about a clutch. If you're clutch is lasting and getting the power down (good 0-60 ft times), then maybe a custom tune?
Old Jan 17, 2005 | 07:08 PM
03EvoVIII's Avatar
cams
tke_413's Avatar
Originally Posted by 03EvoVIII
cams
Read the first post again.
Old Jan 17, 2005 | 07:09 PM
sleet's Avatar
If you want help, you're gonna have to change the attitude a bit
evo_dadi's Avatar
^^ clutch is a must then injectors,cam gears.if you got some more money to burn an o2 housing and a few gallons of race gas
Old Jan 17, 2005 | 07:12 PM
03EvoVIII's Avatar
I guess I should read the whole thing before I open my mouth
In that case probably a clutch
housedj's Avatar
Thumbs up
sell the emanange & get the AEM EMS. i would also consider injectors (at least 800cc), fuel rail, fpr, & maybe some drag radials for the track. if you add cams, make sure to get new retainers, lifters, & ARP head bolts for added safety & a rock solid top end. with these items you should hit high 11's but the stock turbo will still run out of steam.
Old Jan 17, 2005 | 08:01 PM
MitsuJoe's Avatar
whats wrong with the emanage?
I would consider clutch, custom dynoflash, cams, 10.5 housing, and a header.
Old Jan 18, 2005 | 09:08 PM
jrhecker's Avatar
appreciate the advice (as opposed to the lecture), i guess i should clarify a bit more, i don't go to the track, i mostly run with my buddies 40-120 the clutch issue is not a big thing for me, i never launch my car, and i mean never, i have 25k miles on the car, i began modding at 10k and have had no issues with clutch, brakes, etc.. i do all my mods myself,
i am holding off on the stand alone for another year, the emanage will do a fine job with the cams etc.. i am not sure about injectors, keep the thoughts coming, all advice is appreciated
Old Jan 18, 2005 | 10:02 PM
ctx2000's Avatar
go with cams 264/264, but if you want to change to a bigger turbo..........272 is the king.
Old Jan 18, 2005 | 10:06 PM
escoson's Avatar
if i had the mods you had and was looking into running 11's i would consider what he has said. or you can go all out and do some insane setup if the funds will allow it!
Old Jan 18, 2005 | 10:38 PM
EidolaDream's Avatar
if your getting cams, you should get the gears to go with them, they will be happy.
