QUESTION! Evo Bumpy Ride?!?
Old Jan 19, 2005 | 06:42 PM
J8dailo's Avatar
ok, i know the evo have stiff suspension... but right now... it drives worse than when i first bought it... even on complete smooth roads...it bumps like crazy... i don't think thats normal...i call the dealship as usually...they just told me probally my tires are frozen? and check the pressure..?? i did..and pump the tire back to good runnning pressure...its still really bumpy...
i have about 3000 miles on my car...is it time for me to go in for a check-up? i think my wheels could be offset... any advises?
Old Jan 19, 2005 | 06:44 PM
plokivos's Avatar
your tire pressures are frozen? what is that mean?
what's your tire pressure set at?
if it doesn't squeek, your shocks are ok. it's bumpy, you don't realize it when you first get the car.
Old Jan 19, 2005 | 06:45 PM
KillaSweep's Avatar
the ride is bumpy stock....if it is cold and you are on the stock tires they tend to get harder when its cold.....
Old Jan 19, 2005 | 06:49 PM
J8dailo's Avatar
no..he said my tires could be frozen? i don't know what he meant..probaly ice on my tires? i know stock is bumpy..i know how it felt like...just recently...if u go on smooth tracks...its bumps like crazy... i thought it could be the tire is not align right ...is it time for a check up? 3000 miles?
Old Jan 19, 2005 | 07:33 PM
J8dailo's Avatar
when do people usually take their car in for check up? on evos
Old Jan 19, 2005 | 07:41 PM
RaceBiscuit's Avatar
Only when something's wrong with it. Has the weather just gotten colder recently where you live? If so, that could be all it is and thus, nothing to worry about...
Old Jan 19, 2005 | 07:43 PM
EVOlutionary's Avatar
Where do you live and how cold is it. One time with my stock tires it was very cold, 10-15 degrees F, and I think the tires "froze" with a flat spot on them. When I started driving it felt like a couple of the tires were badly out of balance and the vibration went all through the car. After I drove a few miles and the tires heated up it went away. Could this be what you are describing?
EVOlutionary
Old Jan 19, 2005 | 09:10 PM
EidolaDream's Avatar
take it in, simple and easy.
Old Jan 19, 2005 | 09:14 PM
escoson's Avatar
i notice when its cold it takes a bit for the tires to warm up.
Old Jan 19, 2005 | 09:15 PM
plokivos's Avatar
you know the suspensions gotta warm up too, the gas on the struts.
Old Jan 25, 2005 | 06:28 AM
SillySpheres's Avatar
I have the exact same problem every morning, especially when the temperature was sub zero the previous night. It can be worse when it snowed previously and snow cakes the wheel and brakes. Braking performance is also greatly diminished and the ABS becomes hyperactive when I am approaching a stop light. It goes away after I have been driving for a few miles though.
Old Jan 25, 2005 | 06:42 AM
kapolani's Avatar
You need some winter air in your tires.
Go get it changed.
You may need some piston return springs as well.
Seriously... Your best bet is to take it in and have them take a look at it.
Old Jan 25, 2005 | 07:19 AM
mifesto's Avatar
the springs are cold so its stiffer as well the shocks themselves.... and i bet you are driving on the advans in the cold too..
i would wait til the weather gets warm to complain.
Old Jan 25, 2005 | 08:09 AM
gtr's Avatar
gtr
Shock are stiff when warm and really stiff if freezing outside. Perhaps you should consider getting some MR shock setup since it give a much softer ride without compromising performance.
Well, really soft in comparson to my 03 evo that is.
Old Jan 25, 2005 | 08:36 AM
steveevo8's Avatar
yeah well if you have yoru summer tires on for some reason, that could be a reason... i know my ride isn't has bumpy with my winter tires on, but with summers i can most def feel everything in the road....
