QUESTION! Evo Bumpy Ride?!?
Old Jan 25, 2005 | 08:39 AM
WildRice's Avatar
The damper fluid is more viscous when cold. The tires side walls are stiffer when cold. Take your car out and romp it good for about 20 minutes and see if it feels softer. When struts fail you will get a very loose feeling car, if one jambs you will also bre able to feel it in the handling, there really much else that is likely to change the ride characteristics on and undamaged car.
I hope the dealer did not give you the impression that you should increase your tire pressure to soften the ride. Lower tire pressue softens ride but has drawbacks. It degrades turn in and may allow rollover of sidewall. If your side wall rolls over very far it can scrub and will cause the car to wobble during transitions.
Old Jan 25, 2005 | 01:42 PM
J8dailo's Avatar
well..the weather is finally getting warm over here.... thats good news..
bad new is...my evo still feel crazy bumpy!!...feel like im running over grounds of broken branches
Old Jan 26, 2005 | 02:10 PM
Jakeg97's Avatar
the evo rides bad . i cant imagine it worse.
Old Jan 26, 2005 | 02:30 PM
J8dailo's Avatar
imagine feeling like driving over pile of pebbles when the road is perfectly smooth... its alot worth than when i first bought it
Old Jan 26, 2005 | 02:38 PM
alby988's Avatar
Originally Posted by gtr
Shock are stiff when warm and really stiff if freezing outside. Perhaps you should consider getting some MR shock setup since it give a much softer ride without compromising performance.
Well, really soft in comparson to my 03 evo that is.
do MR's shock setup (Bilstens?) have a softer ride feel?
if so, can i swap mine from my 05 gsr
Old Jan 26, 2005 | 04:53 PM
EVOlutionary's Avatar
I can't believe I didn't think of this sooner. The last few replies make me think of this -
Could your wheels be out of balance? This will make the tire hop up and down a little bit if it is bad. When I get snow packed in one (or all) of my wheels the steering wheel vibrates, the car vibrates, and like you said it feels like you are driving over a bunch or pebbles or on a dirt road.
If your wheels are clean of snow, take your car back to the dealership and have them balance your wheels/tires for free, or take it to Discount Tire and pay $20-40 to have them do it.
EVOlutionary
Old Jan 27, 2005 | 09:58 AM
J8dailo's Avatar
EVOlutionary
thats exactly what i was thinkin...even though i only have >3000 miles on it
how can it be out of balance so soon...i havent raced it or do track event in it at all
Old Jan 27, 2005 | 10:20 AM
Maybe one of the balance weights fell off? Maybe you hit a pothole and it tweeked your alignment? Who knows. If it's really that bothersome, take it in to the dealership and have them go on a test drive with you. They will know if it feels normal or not.
EVOlutionary
heSOshAdy
12
Jan 9, 2008 07:37 PM
dman9271
24
Nov 29, 2007 03:27 PM
mattfl
Apr 25, 2007 10:18 AM
chrls000171
Apr 27, 2005 10:17 PM
