what is 10.5 hotside>?
Old Feb 4, 2005 | 12:59 PM
evilution8's Avatar
i see its only 230 bones which isnt bad. what kind of HP increase are we talking here??? also how is install??
Old Feb 4, 2005 | 01:06 PM
RallyRedEVO's Avatar
Well, install is a bit of work. I had Dyno4mance do it for me.
Here is my dyno graphs before and after. The numbers on one graph are for race gas, and the other are pump so ignore those. The bottom lines on both are pump, so that's the comparison. You can kinda see the gains, it'd be easier if I had them on the same graph. But it basically enabled me to run my previous race gas numbers on pump gas. And when the turbo spools, it hits like a freaking hammer now!
Before:
After:
Old Feb 4, 2005 | 01:08 PM
evilution8's Avatar
what didt hey charge you like 1-2 hours of labor. the part is only 230 it would seem ridiculous to pay more than that for install. most places around here are about 70-90/hour.
Old Feb 4, 2005 | 01:35 PM
PM'd you, not sure if I should post those things on here.
Old Feb 11, 2005 | 07:50 PM
megatron's Avatar
is the 10.5 hotside for $230 good enough of is the entire 6.5 titanium alloy turbo for about $1000 worth it?
Old Feb 27, 2005 | 09:39 AM
lil'evil_evo's Avatar
Can anyone tell me how much Dyno4mance and Vishnu sells them for?
Old Feb 27, 2005 | 09:51 AM
k.lowe's Avatar
Originally Posted by RallyRedEVO
It's a cheap can of whoop-a$$!
I made 296 WHP with 93oct on a DynoDynamics with a Vishnu Stage 1 ( 3" exhaust, CAT delete, cam gears, fuel pump, piggy back computer, and 10.5 hotside ).
The measurment is decieving, it's not a larger exducer bore which most people think, the 10.5 has a greater volume inside.
Andrew @ Dyno4mance can hook you up, and can install it if you are close. I can attest to the fact that he does top knotch work.
**** get some 272s and you will be over 320 hp
