Dive by wire?
Old Jan 10, 2003 | 09:28 AM
djdaizzy's Avatar
Question Drive by wire?
Does anyone know if the US EVO VIII is using drive by wire(electronic throttle)?
Old Jan 10, 2003 | 04:57 PM
2GTSiAWD's Avatar
I highly doubt it..
Old Jan 10, 2003 | 05:27 PM
BurnOutz's Avatar
Whats the benefits of this system anyways. From what it sounds like, it seems as though there will be less feeling of the throttle.
Guack007's Avatar
I hope they dont change it to some ****ty electronic throttle.
Old Jan 10, 2003 | 07:23 PM
chronohunter's Avatar
I hope it dosen't have it. Those systems are usually done for emissions reasons and usually hurt throttle response especially when you lift of the gas (to get the car to tighten its line in hard cornering). They make the engine feel slugish and unresponsive (usually)
Old Jan 10, 2003 | 10:55 PM
hornet's Avatar
I test drove a Nissan Altima 3.5 SE and they have electronic throttle, from my experience with that car it seemed pretty responsive (although it was only a test drive and can't account for a lot of other variables).
Old Jan 11, 2003 | 01:20 AM
RaX's Avatar
RaX
The new USDM STi has electronic throttle (drive by wire).
I don't know what that means from a tuning standpoint though...
Old Jan 11, 2003 | 01:20 PM
Guack007's Avatar
I drove the 3.5L maxima and every time you take your foot off the gas to shift the rpms keep going for about 300 more revs than when you took your foot off so the chip can send the signal to the throtttle to close. It takes extra time thats not needed. Yes it does feel a hell of alot slower than it should be to respond. However when it does respond it is very fast and very powerfull, (for its class). Some companys like to use the electronic throttle to vary how much the throttle opens reletaive to pedel movement. I personnally like to move my foot more to get more power. Another flaw in the nissan (even the 350Z) elect. throttle is that it cuts power to 25% maximum at "WOT" if the brake and gas are applied at the same time. Thus no left foot braking . Ive given several resons to not use electronic throttle, anyone have a reason for it?
PS this is my 350th post, when do I become Evolved?
Old Jan 11, 2003 | 10:04 PM
ACM's Avatar
ACM
I had a Mazda some years ago that would hold the throttle open (via the ISC) for a count of 3 after I got out of the throttle. Buried me in snowbanks about a dozen times the first winter after I bought it. I *****ed and whined at the dealer and the area rep, all I got was 'it's not a race car, why are you driving it like that'. I sold it with 15k on it. It doesn't take d-b-w to screw things up...Just thoughtless engineers.
Charles
Old Jan 14, 2003 | 03:23 PM
Guack007's Avatar
good point.
Old Jan 14, 2003 | 03:33 PM
iodine23's Avatar
Some cars with electronic throttle simply use throttle pedal position as an indication of how fast you want to go. That is to say that throttle plate position is not directly related to pedal position. Other cars provide a 1:1 linear mapping, I think the Z does as mentioned above. But as was also said, it cuts throttle to 25% when brakes are on. It's an "anti-stupid-driver" feature I guess. Why would you EVER want to gas and brake at the same time?
But if you have an electronic throttle that is directly mapped to pedal position, why use an electronic throttle in the first place, right? It's just one more thing that can break...
Old Jan 14, 2003 | 04:47 PM
Daveyd's Avatar
KK, Maybe you can tell us how many posts get us to each "level"..
Old Jan 14, 2003 | 04:57 PM
xenomorph's Avatar
Originally posted by chronohunter
IThose systems are usually done for emissions reasons and usually hurt throttle response especially when you lift of the gas
I've noticed this as well. Several BMWs and audi's with electronic throttles keep the revs up for a count or two and then the RPMs start to drop. however, I've not noticed this to any significant degree on the E46 M3
/v
Old Jan 14, 2003 | 05:16 PM
Yojimbo's Avatar
Through some browsing of the members list I've determined that Evolved Member shows up around post number 400.
I have a question for Mark though. Everyone is an Adminstrator who has a substantially larger number of posts than the Evolved Member cutoff. Since they're Admins we don't see a title and I'm extremely curious what the "super huge number of posts" title is?
Old Jan 14, 2003 | 06:04 PM
Guack007's Avatar
Ever heard of left foot braking. There are also times when I like to rev match the gears into downshift while im braking into a corner.
PS thnx for the evolved info.
