What is the best intake
Old Feb 10, 2005 | 05:08 AM
RallyRedEvo05's Avatar
I would reccomend the hkr rs intake gains are extremely good once its tuned for the car 2 thumbs up for hks intake =)
Old Feb 10, 2005 | 05:11 AM
Tsurara's Avatar
Hows does the HKS RS do against the APEXi intake + induction box?
Old Feb 10, 2005 | 02:42 PM
e&nevo's Avatar
I like my injen intake.
Old Feb 10, 2005 | 02:48 PM
sexynuts(.)(.)'s Avatar
Wouldnt dropping in a k&n filter make the turbo spool better and make the bov more audible? If it would then I would get that over the hks intake, especially if it only makes approx 5hp (assuming you are not going to get the car tuned).
Old Feb 10, 2005 | 05:56 PM
stanimal8's Avatar
Stock with K&N panel filter is best if you're not runing a stand-alone ECU or have had your chip reflashed.
On most EVO's, major changes in intake will cause the ECU to reduce boost.
But if you're running a stand-alone ECU, the bigger the intake, IC pipes and intercooler the better.
Old Feb 10, 2005 | 06:00 PM
hueman's Avatar
would the apex box even fit the hks intake pipe mated to the apex filter?
