All Part Number Request Go Here
Old Oct 23, 2007 | 08:48 AM
  #2131
RussellM's Avatar
Plat Vendor
Originally Posted by budlong
the smoked plastic lense that the clock sits behind, not the clock itself, just the lense/cover.
evo IX
It appears that the clock is sold as one unit.
http://www.mitsubishiparts.net/cart/?id=571&pn=MR962799
Old Oct 23, 2007 | 08:51 AM
  #2132
RussellM's Avatar
Plat Vendor
Originally Posted by Greg K
Rear wheel bearing assy.
http://www.mitsubishiparts.net/cart/?id=571&pn=MR403968
Old Oct 23, 2007 | 10:05 AM
  #2133
InDub's Avatar
03 evo fuel pump hanger please. Is it sold as one unit or can you buy the sending unit, hanger, etc seperate? Im looking for the suction assembly.
Thanks!!
Old Oct 23, 2007 | 01:58 PM
  #2134
lilnaz's Avatar
nm found it under different name/search
TYVM
Old Oct 23, 2007 | 04:35 PM
  #2135
RussellM's Avatar
Plat Vendor
Thanks!!
Im pretty sure you are needing the pump, but I asked someone else here if they could make heads or tails of it 100% because I was slightly uncertain and they felt the same way. So here is an illustration of the fuel pump parts. Let me know which you are wanting.
Old Oct 23, 2007 | 06:31 PM
  #2136
InDub's Avatar
Thank you, i just got home and ended up just going to the dealer and figuring it out since they are so inexpensive. Im sure ill order from you in the future. It was #05220 fyi. Thanks
Old Oct 24, 2007 | 05:49 PM
  #2137
cmz's Avatar
cmz
what are the part numbers for the washers on the drain/fill plugs for the:
- tranny
- transfer case
- rear diff
Old Oct 25, 2007 | 08:58 AM
  #2138
EvoDan2004's Avatar
Can anyone help me out here I have an 03 evo8. I'm removing the a/c.. So I need a new belt. Can someone tell me the oem part number for the belt that works with OUT the a/c or where I can get one. Thanks. I here the 04 evo rs without a/c will work. Idk though
Old Oct 25, 2007 | 06:14 PM
  #2139
EvoDan2004's Avatar
i also need the evo rs black door handles. not the locks. just the black door handles. f/r anyone got a part number.
Old Oct 25, 2007 | 10:53 PM
  #2140
ill-luzion's Avatar
i need the mivec cover bolts. the 4 small 12 point bolts that hold the mivec case.
Old Oct 26, 2007 | 10:01 AM
  #2141
RussellM's Avatar
Plat Vendor
- tranny
- transfer case
- rear diff
Here is a link with all the parts. Sorry about the delay in the response on this -- Im pretty sure we NEVER have a full crew here and it gets crazy hectic.
http://www.mitsubishiparts.net/cart/...5D=1&pn=update
Old Oct 27, 2007 | 10:18 AM
  #2142
joosdawg's Avatar
rear motor mount plate that bolts to tranny... please help asap find the part # for that piece on a 05-06 MR 6spd
**edit** part # found thanks to rusellM
Old Oct 28, 2007 | 02:18 PM
  #2143
cmz's Avatar
cmz
Thanks RussellM,
MB001265 - Plug Kit+fr Diff
MN130495 - Gasket+a.t Case
MB001261 - Plug Kit+rr Diff
MB569390 - @ Plug Kit+rr Diff
Old Oct 29, 2007 | 01:35 PM
  #2144
ill-luzion's Avatar
any help with the mivec cover bolts?
Old Oct 29, 2007 | 04:55 PM
  #2145
cssaddictm4's Avatar
Name this part number!!!
I am almost done doing my 5spd conversion, but I am missing one part!!!! The local mitsu dealer seems to be no help. This part is in the service manual as the "Gear Shift Lever Retainer" for the 5spd. Any help is much appreciated!!!
Can some one confirm it is MN168249?
Thanks, Blake.
